Converting to a/c brackets/ Vintage Air
What is wrong here?
i have the C style Alternator bracket.
i THINK the power steering, crank and water pump are from an A/c car. But not 100% as I bought the car disassembled.
the Compressor is a Saden from Vintage Air with the passenger side bracket option.
the Pullys do NOT line up the way I think they should.
notice the innermost Waterpump/crank Groove does not meet up with innermost Power Steering?
the Alternator meets with innermost Power steering and middle Crank and Water Pump.
the Outtermost water pump and crankmeet with outtermost Power Steering.
this leaves the Two Saden grooves with nowhere to attach!
(my reference is my GMC Motorhome with a 455. The innermost power steering, crank, waterpump all one belt. Then middle of Waterpump and crank meet with Outter of Power steering and the Alternator. Then the outter Water pump and Crank meet the A6 compressor)
do I have a mix of wrong pullys?
Additional notes
the Pulley on waterpump and crank MAY be from a 350. The car was a Cutlass Supreme i THINK with a 350. The engine and other stuff is a mix the previous owner left me in a pile. The valve covers are from 73 Olds Toronado. I am not positive of the power steering pump bracket.
As usual, mixing and matching pulleys, water pump, and brackets doesn't work.
It would help to know which pulleys and water pump you have. My gut feel says that you have the water pump and crank pulleys from an earlier motor, and a water pump that is too short. I'm sure the VA kit is only designed to line up with 68-72 pulleys, since no vendors assume any Oldsmobiles exist outside those years. Your alternator bracket is also from that vintage, so it matches the A/C. I'm guessing that you need a KC crank pulley (P/N 399405) and a KF water pump pulley (P/N 399404) for a 5.6" water pump. If you have a 6.1" water pump then you need a KK water pump pulley (407534).
I have no clue what the previous owner had or bought. here is a shot from Alternator. I may be parallax but seems like alternator may actually line up ok with innermost Crank and Waterpump pulley groove and the Power steering is the pulley that is too far toward front of car?
How much room is there between the correct 399405 Crank pulley and 455 shroud? I am getting close. Any way to tell which pulley i have?
Looking at the water pump pulley it has a much deeper neck than one at OPGI website.
i live near OPGI so i guess it cant hurt to take these off and go to OPGI and see if the ones they have are different.
I would not buy anything until you figure out which water pump you have. Your current water pump, WP pulley, and crank pulley all match each other. They just don't match your current accessory brackets or pulleys. The pulleys I noted above will have the innermost groove where your middle groove is currently, the middle groove where your outermost is currently, and the outermost groove the same distance closer to the shroud. Obviously you need BOTH the crank and water pump pulleys to match.
good lord! I knew the lot of dissassembled Oldsmobile car was a 1970 Cutlass Supreme and a little 73 Toronado, now add in a 78-80! Ok thank you. Does the Power steering pump “match” up?
I got the new water pump pulley I ordered from OPGI.
Side by Side the “v8 3 groove pulley for 68-73” is exactly the same.
the innermost groove does not line up with the water pump pulley
the choices on OPGI were many but process of elimination the one I bought seemed right but picture shows a shorter neck than what I received.
Which is correct one from OPGI?
Why do you ask for help if you are just going to ignore it? And why do you think that a Chevy-centric vendor like OPGI has a clue as to what is correct for an Olds?
One more time: your water pump is a 5.6" pump. You need KC/KF pulleys. The OPGI pulley you bought, and the one you have, are for a 6.1" pump.
They only have two 3 groove listed. The second row one is wrong. I ordered top one with no GM part number listed. What came did not match photo. I weirdly they do say the part number for third row one but not top row one. What came was the third row one. I think they miss labeled the parts?. There is NO stamp on it to confirm what K number it actually is but clearly it is wrong
I found the right one. This place actually listed the part number and K number. It looks like the right one.
I am not sure what those other two Three groove versions are used on. They both said V8 with A/c.
https://www.ebay.com/itm/68-70-OLDS-...id=28007622593
Just wondering if the comp lined up ok. I am trying to do the same thing but have a 6 in water pump. I am waiting for the vintage air kit to arrive. Right now i have a ks crank pulley, cant read the water pump but it does line up with the crank.
What compressor bracket are you using? I’m using Vintage Air 141008.
Their guys told me they didn’t have a bracket for a 67 Olds 330 but the install instructions said it would fit so I tried it and it works perfect for me.
Oldssupreme
April 15th, 2018 06:06 AM
