69 W30 442 Post Restoration
Old Sep 22, 2024 | 06:12 PM
  #161
v8al's Avatar
Registered Olds Owner
This car has come a long way from where it started. Looks good! Keep it up! Hopefully will be driving next summer!
Old Sep 22, 2024 | 06:40 PM
  #162
nick@wri-net.com's Avatar
Weav2-69s
Today I took my hood and fenders off to work on all the gaps, I think I got them the best it’s gonna get. Im going for OEM look
Old Oct 1, 2024 | 01:30 PM
  #163
kjr442's Avatar
Kjr442
Forward progress
You have made great headway. I love seeing the changes as you go along. This is a far cry from where it started off at when you first got it.
Old Oct 18, 2024 | 12:15 PM
  #164
Kevin's442's Avatar
You, Sir, are doing some fantastic work. Hats off to you!
You probably already know this, but just in case. 69 442's don't have the Oldsmobile script emblem on the driver's side lead edge of the hood. Cutlasses and F-85's did, but 442's didn't. At least the two 69 442's I've owned didn't. Didn't want to see you get the hood in primer and then have to go back and weld the holes shut. Keep up the good work!
Old Oct 20, 2024 | 05:02 PM
  #165
Weav2-69s
Yep I welded those up couple weeks ago. This October marks the one year anniversary of this project, today I got 2 coats of epoxy on it. Next I’ll spray 3 coats of high build and start block sanding.
Old Oct 20, 2024 | 06:11 PM
  #166
Big Dawg's Avatar
Beautiful work!!!!!
Old Oct 21, 2024 | 07:30 PM
  #167
Weav2-69s
Ok I got 3 coats of high build on tonight now she’ll sit and cure for 7 days at 75 degrees, block sanding is next on the list
Old Oct 22, 2024 | 02:43 PM
  #168
Kevin's442's Avatar
Sanding primer
Oh boy! My favorite! Block sand till you think your arms are going to fall off then sand some more. But seriously, it has to be done and then it will look amazing. You're doing great!
Old Oct 22, 2024 | 04:40 PM
  #169
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Nick,
You are going with the trim tag colors... code 69 Platinum n black gut?
SS1, SS2, poverty caps, Cragar SS...trying to get the visual at the end.
Gotta see this thing in person when its done.
Old Oct 31, 2024 | 06:31 PM
  #170
Weav2-69s
We re taking it back to factory, platinum with black hood stripes and black interior. As for wheels I have 2 sets, 1 set of 14x6 NOS SS1 s with Goodyear Polyglass tires and a set of 14x6 steels with NOS poverty caps with Redline tires. Was planning on using poverty caps at Lansing and Olds National shows. SS1s for local shows.
Old Oct 31, 2024 | 06:42 PM
  #171
Weav2-69s
Quick update I’ve been block sanding since Sunday, should have first round of sanding done this weekend then I’ll start working on working the fill in the low spots. After that 3 more coats of high build then start process all over again. I used PPG Omni epoxy then 3 coats of feather fill and I’m gonna use rage gold for the filler.
Old Nov 12, 2024 | 10:03 AM
  #172
kjr442's Avatar
Kjr442
Sanding
The torturous process of sanding sucks, but it’s the foundation for a beautiful car.
Congratulations on a remarkable resurrection.
Old Nov 12, 2024 | 10:25 AM
  #173
Pro tip....mock up the upper stainless trim to make sure it runs down the body straight. It has an arch to it that needs to "flow"
It's the fender-to-door alignment that looks like schzit if it's off. It is a problematic spot and was rarely really nice from the factory. IMO its the toughest area to get right on 68-69s.
Old Nov 12, 2024 | 06:14 PM
  #174
Bernhard's Avatar
Nice progress. What are you using for blocking?
Old Nov 12, 2024 | 06:57 PM
  #175
Weav2-69s
Thanks for the tip sir, my passenger side fender does need to move down a fuzz were it lines up with door. I mocked up all the trim a little while back everything lined up pretty nice. I will say that my NOS fenders were tough to get adjusted, more so by the doors to get them to follow the shape of the doors. I’m using paint sticks as blocks. I wood glued 3 sticks together and have them in lengths from 3” to 20”s. I’m also using a 1” dowel rod ab 8” s long for the areas on top of the door and on the hood. Guided the car then blocked it with 80 grit , guided coated again then blocked it with 150 grit. Fixed all the low spots with Rage Gold filler. The plan this weekend is to get a couple of coats of 2k primer on let it sit couple days then block it with 220 grit. My goal is to have it apart and on the rotisserie at the beginning of December. Here’s a couple pics I took before I sanded the last of the low spots
Old Nov 12, 2024 | 07:07 PM
  #176
Weav2-69s
Also I noticed this weekend that my passenger door was a 68 door, I have 2 other 69 passenger doors so I was able to modify my 68 door into a 69 door. I noticed the difference sitting on a stool staring at the car. I do that from time to time to see if anything sticks out that I’m missing. It works for me I’ve caught few things by doing it.
Old Nov 12, 2024 | 07:49 PM
  #177
Good catch!
Nice graft.
Its really looking good. Cant wait to see it in paint...I'm sure its the same for you.
Old Nov 16, 2024 | 04:48 PM
  #178
Weav2-69s
Today I got 2 coats of PPG Deltron on the car I’m gonna let it sit for a couple days then block sand with 220 grit
Old Dec 9, 2024 | 07:50 PM
  #179
Weav2-69s
Quick update tonight I put another 2 coats of 2k on and will let it sit till Saturday then block sand with 400 grit, as long as everything sands out good the next step is disassemble car and put it on the rotisserie
Old Dec 10, 2024 | 05:19 AM
  #180
Lines look better than they did in 69. Great work. Are you a trained bodyman of just a prefectionist?
Old Dec 10, 2024 | 06:14 AM
  #181
Weav2-69s
I’m actually a union carpenter by trade, but in the process of building this car ultimately I’m gonna be judged by my Oldsmobile peers and I want everything to be as close or a little better then from the factory. I really do enjoy the body work side of it though, there still a few things iron out but it’s getting closer.
Old Dec 11, 2024 | 10:08 AM
  #182
Ahhh, a skilled woodworker explains the outrageous garage and the flat panels on your car.
Old Dec 11, 2024 | 06:06 PM
  #183
Weav2-69s
Last night I cleaned my inner fenders with some gas then wet sanded them with vinyl cleaner and 800 grit and 1000 grit. Once they dried out I wiped them down with Chemical Guys tire shine here’s a couple before and afters
Old Dec 11, 2024 | 07:04 PM
  #184
jmcghee's Avatar
Inners came out real nice
Old Dec 12, 2024 | 08:05 AM
  #185
Cfos0031!'s Avatar
Very nice work Nick!
Old Dec 12, 2024 | 06:33 PM
  #186
Weav2-69s
Thanks Craig
Old Dec 12, 2024 | 08:46 PM
  #187
kjr442's Avatar
Kjr442
Front fender wells
Wow Wow Wow!! Those turned out great!
this car is going to be amazing. I can’t wait to see this thing when it is finished.
Old Jan 12, 2025 | 07:29 PM
  #188
Weav2-69s
I got a little bit of progress done over the holidays, the car was completely wet sanded the front end was taken off to prep core support and inner fenders for primer. Along with underside of hood and trunk. Also got the call from machine shop that everything was completed and ready for pick up. This week I’m gonna try to paint the underside of the hood and core support. Getting closer to getting the body on a rotisserie.
Old Jan 14, 2025 | 01:22 PM
  #189
Cfos0031!'s Avatar
Looks nice!
Old Jan 14, 2025 | 01:24 PM
  #190
rickw30's Avatar
Looks awesome !
Nice core support.
Old Jan 20, 2025 | 05:51 PM
  #191
Weav2-69s
Got underneath the hood painted black and core support too,I used GM restoration satin black paint. I like it more than Eastwood chassis black satin. Eastwoods satin still seems to glossy to me. Also got the body separated and getting ready for rotisserie
Old Jan 26, 2025 | 05:42 PM
  #192
Weav2-69s
Another big step this weekend i got the firewall and dash painted, also got this baby on the rotisserie finally. Started to feel like it was taking forever to get to this point. Here’s a few pics let me know what you think.
Old Jan 26, 2025 | 05:51 PM
  #193
old80cs's Avatar
Been following along, you’re doing a great job on that car!
Old Jan 26, 2025 | 07:52 PM
  #194
442Dude's Avatar
Great work. Looks allot like what I just did to mine just a few years ago.
Old Jan 27, 2025 | 06:47 PM
  #195
Weav2-69s
Thanks guys hopefully it’s in the paint booth end of February
Old Feb 3, 2025 | 07:54 PM
  #196
Weav2-69s
I got the underside of the car painted this weekend and primed the trunk. Everything is seam sealed so I’ll paint trunk black this week then clean everything. I have a few things to do on the chassis, brake line and fuel lines. Then body goes on the chassis. It will be at the paint shop the week of February 17.
Old Feb 3, 2025 | 09:29 PM
  #197
Nick,
Nice work. Cant wait to see it in paint.
Was thinking while you have access to spots you will not have access to once you start bolting it together, you may want to think about LPS3 Krown Fluid Film etc.
Under the dash, trunk drop offs, inner rear wells, front fender dog legs floor braces, in the cowl, and all the other inner seams etc.
I use Krown Fluid film and LPS 3. All 3 simply stop rust. Even if you live in Phoenix.
https://www.itwprobrands.com/resourc...tween-lps1-2-3
https://shopusa.krown.com/products/k...ase-of-6-or-12
Old Feb 4, 2025 | 02:50 PM
  #198
Cfos0031!'s Avatar
You are not painting the body yourself?
Old Feb 5, 2025 | 07:02 PM
  #199
Weav2-69s
I’m taking the car to our vice president of of our olds chapters body shop, he s gonna let me use his paint booth and teach me how to paint. I’ll be with him every step of the way. He wants to be apart of the build and I’m willing to learn anything peo-le have to offer.
Old Feb 5, 2025 | 08:05 PM
  #200
Cfos0031!'s Avatar
Can't wait to see it in paint!
