'65 F-85 Club Coupe
Old Dec 19, 2022 | 07:16 AM
  #161
67OAI's Avatar
Old(s)GuysRule
Looking good Peter!
Old Feb 10, 2023 | 08:50 PM
  #162
65droptop's Avatar
Fired it up tonight!!!
I can’t believe how quickly it started.
I made a little video to show how to start an engine up in a frame as a stand alone unit.
https://youtu.be/57-B-wP9eiI
vroom vroom, i can't wait
Old Feb 10, 2023 | 08:52 PM
  #163
66SportCoupe's Avatar
Sweet!!
Old Feb 15, 2023 | 06:26 AM
  #164
kjr442's Avatar
Kjr442
Nice work Pete
Caught up on this thread. Pete you are knocking it out of the park. Great progress.
Old Feb 25, 2023 | 04:52 AM
  #165
Rallye469's Avatar
Well it’s been a while since an update.
Took a little time off of this to do some maintenance and enjoy the 70…but now with the frame finished I’m onto the body.
Bought a great body cart from Redline and got it ready for stripping.
Heres where inexperience has cost me a little.
I always planned to do the frame, body, and underside down to bare metal, but doing the underside before stripping the top side was kinda dumb. I should have had the entire car stripped and started from there. Luckily I didn’t ruin the underside, but there was a bunch of clean up.
Old Feb 25, 2023 | 10:27 AM
  #166
kjr442's Avatar
Kjr442
Smart work
You stayed away from the roof seam, smart move.
I am very impressed with the condition of this body.
Old Feb 26, 2023 | 05:18 AM
  #167
Rallye469's Avatar
Yep. I wanted to sneak up on it with a DA and save myself a possible headache.
you can also see evidence of a slide hammer pulling out the metal all the way down the right side.
very little rust, but evidence of some trauma at some point.
Old Mar 12, 2023 | 03:52 PM
  #168
Rallye469's Avatar
Where to start…
I got a lot done considering I was fight flash rust AND the fact that I don’t know how to use a spray gun.
lotsa prep and reprep and fast etch and more prep…
But I finally got 2 coats of epoxy on the car. I didn’t keep a very good wet edge on the paint so it’s a little streaky. That ANF a bad regulator made the first coat go one like ****. (Buy the quality **** people).
Old Mar 12, 2023 | 04:03 PM
  #169
Rallye469's Avatar
This weekend I decided to attack the fenders.
The fenders looked ok but the braces needed some work.
Ive been trying to sell a set of 64 fenders for ages($200???) to not avail.
Well I’m glad I didn’t sell them because one of them gave their life so I could steal the brace for the 65.
(zero F’s given)
The other was just patched with some sheet metal.
Also had to fill in the antennae hole some yahoo made on the drivers side.
My car wasn’t order with a radio so the fenders were never punched.
Even test fir some chrome just to see how they fit. A little hammer and dolly and viola!
After prep I did a much better job with the spray gun. Minus some dust they’re great.
Now it’s time for filler!!!
yay.
Old Mar 12, 2023 | 05:38 PM
  #170
Amazing work Peter!
Old Mar 12, 2023 | 07:00 PM
  #171
Eddie Hansen's Avatar
Sweet
Really nice work it’s looking great Peter
Old Mar 12, 2023 | 07:23 PM
  #172
Tj Pal's Avatar
Wow! Great work.
Old Mar 13, 2023 | 06:31 AM
  #173
Rallye469's Avatar
Thanks guys...she's coming along.
All I have to do now is firewall, drop body on frame, hook up all the lines, all the glass, the body work, the electric, the dash, the paint....
Ugh.
Old Mar 13, 2023 | 07:37 AM
  #174
67OAI's Avatar
Old(s)GuysRule
Lookin' good Peter! How much yard cleanup was required after the blasters?
Old Mar 13, 2023 | 12:31 PM
  #175
Rallye469's Avatar
It’s a beach Jim!
Old Mar 16, 2023 | 01:32 PM
  #176
Rallye469's Avatar
Prepping the hood...about 5 hours of sanding, wire wheeling and blowing all the sand out of the crevices.
I had a problem when it was blasted. The blaster removed the panel bond/seam sealer which caused the hood to warp or "oil can"
But some cardboard spacers and new sealer has taken up the space and cured the problem.
Glad I could save this beautiful hood.
Old Mar 16, 2023 | 02:26 PM
  #177
kjr442's Avatar
Kjr442
Progress!!
Pete you have energy I wish I had again.
Awesome progress my friend. Right
Old Mar 19, 2023 | 02:34 PM
  #178
Rallye469's Avatar
A big set back totally killed my drive this weekend.
After getting the bottom of the hood prepped and painted with welding the trim holes in for the club coupe spear…
I flipped it over and the damn thing was warped SOOOOOOooooooo badly.
I think this was from the media blasting.
Like so bad the frame pattern was showing through the skin with just a light pass with 120 grit.
Im still pissed I ruined such a nice hood.
LET THAT BE A LESSON TO YA.
DO NOT BLAST HOODS.
Trash.
garbage.
Old Mar 19, 2023 | 09:12 PM
  #179
Nor totally garbage. Sand it all out. Might not be as bad as you think. However blasting a hood cam cause warpage.
Old Mar 19, 2023 | 09:14 PM
  #180
Flat board sander might make you think again
Old Mar 20, 2023 | 06:53 AM
  #181
Rallye469's Avatar
I worry about how much filler it would take to make this hood flat again...each of the 4 windows in the frame led to low spots.
Will filler over a hot engine react at the same speed/amount as the metal when it gets warm?
I honestly have no idea.
Old Mar 20, 2023 | 07:05 AM
  #182
Even a skim coat of filler over a hot engine will probably not hold up as long as some other place on the car.
Old Mar 20, 2023 | 08:17 AM
  #183
kjr442's Avatar
Kjr442
Metal distortion
Look for an old metal fabricator. Kind of a dying bread, but this can be brought back. Problem is, is it worth it?
Old Mar 20, 2023 | 08:23 AM
  #184
kjr442's Avatar
Kjr442
Happened to mine too
DO NOT BLAST HOODS.
Trash.
Pete the same thing happened to the car I got from Jim. I have pictures after blasting and you can plainly see the under structure of the hood and trunk lid.
can’t tell it now, but I know this could come back on me later.
Old Mar 20, 2023 | 01:03 PM
  #185
Rallye469's Avatar
Yeah...I just think that's WAY too big of an expanse of relatively unsupported metal to blast.
Lesson learned.
Old Mar 20, 2023 | 06:44 PM
  #186
kjr442's Avatar
Kjr442
Technique
It’s user error. You gotta be very careful when blasting large panels. Keeping plenty of distance from the metal and not blasting straight on will keep the heat down. Blast at an angle and stay back from the metal.
it might take longer, but that’s ok.
Old Mar 22, 2023 | 01:42 PM
  #187
65droptop's Avatar
find you a body shop with an old timer, he may be able to heat that hood and get it back.
Old Apr 7, 2023 | 09:40 PM
  #188
Rallye469's Avatar
Well after smoothing the firewall, applying the seam sealer, primer and paint I wasn’t happy with anything…
The sealer looked like crap. The panel was still a bit wavy. And the paint crackled a little.
So…it ALL came off and I’ll try again.
Old Apr 7, 2023 | 09:42 PM
  #189
Rallye469's Avatar
Back to ground zero…
Old Apr 9, 2023 | 01:35 PM
  #190
Rallye469's Avatar
One weekends worth of work and I’m pretty happy I stripped it all back down.
-redid some filler work to lose some dents and dings on the firewall
-primed
-heavier/less flexible seam sealer
-painted
It a touch shinier than I’d want, but it will dull with a little age and road wear.
Old Apr 9, 2023 | 02:59 PM
  #191
Looks really nice!
Old Apr 9, 2023 | 08:01 PM
  #192
kjr442's Avatar
Kjr442
Great work Pete.
Old Apr 13, 2023 | 09:38 AM
  #193
gear head's Avatar
Cool car, I dig it! Looks like you're motoring right on through it and doing some real nice work.
Old Apr 13, 2023 | 11:12 AM
  #194
Rallye469's Avatar
Thanks guys. I'm lovin it.
Hopefully dropping the body back on the frame this weekend.
Old Apr 16, 2023 | 09:41 PM
  #195
Rallye469's Avatar
The body has finally met its new frame.
Very pleased that the trans with the gear vendors clears trans tunnel.
Not please about the height of my new Eaton springs.
Old Apr 17, 2023 | 07:28 AM
  #196
oldstata's Avatar
Justin
I really like the red lines on those wheels!
Old Apr 17, 2023 | 07:19 PM
  #197
Rallye469's Avatar
Kinda like an old HotWheels, right?!
Old Apr 18, 2023 | 02:00 AM
  #198
66-3X2 442's Avatar
Nice work Peter & it was great meeting you. Safe travels my friend.
Old Apr 18, 2023 | 05:58 AM
  #199
Rallye469's Avatar
Great meeting you too Mike!
it was cool seeing all the old racing photos.
And thank you for the amazing parts😁
Old Apr 18, 2023 | 12:46 PM
  #200
oldolds88's Avatar
looks great. i have to chuckle a bit at your door and 1/4, mine was exactly like yours,down rt door and into 1/4. the former owners kids learned to drive in this car. mine was scraped down side,fixed and then again,same spot. probly to close to gas pumps.. are you going back to original color?
