1982 AMC spirit getting 1971 Olds 350
Old November 17th, 2014, 08:12 AM
Marshtonk's Avatar
i had a few guys who wanted to know how the builds going and its a major one so i figured id throw a thread up on it ill post more pictures later
Marshtonk is offline
Old November 17th, 2014, 08:52 AM
cfhcar's Avatar
Smile
cool i'm not alone. I'm putting a 1987 307cid and 200r4 in a 82 amc concord wagon
cfhcar is offline
Old November 17th, 2014, 09:21 AM
Registered car nut
nonhog's Avatar
Subscribed! Love me the engine swaps.
Just yanked a 215 from a 63 Cutlass to possibly go into a 66 Volvo 122.
nonhog is offline
Old November 17th, 2014, 02:08 PM
Marshtonk's Avatar
more pictures of the interior pulled some stuff and other miscellaneous stuff got some engine pics also im going to need some help figuring out whats what with my engine now yeay and the little spot is all for rust on the interior.
Old November 17th, 2014, 03:26 PM
cfhcar's Avatar
how are the inner and outer rocker panels
cfhcar is offline
Old November 17th, 2014, 03:41 PM
Marshtonk's Avatar
the rockers are solid this car has sat in the bottom of a hay field since 1990 i got it on a trade for a 225hp mercury boat motor i got for free so technically the only money i have into it so far is the motor oh yeah more pics coming up right after this
Old November 17th, 2014, 05:51 PM
Marshtonk's Avatar
I have what was supposed to be a 1971 350 rocket out of a cutlass supreme. I thought it had just number 7 heads but after looking into it more its got #7A heads. The block number is 395558 which your sights Oldsmobile wiki stats was used for both 1968-1970 and 1973-1974 casting numbers the crank has the numbers 393654 stamped on it the blocks been bored +.040 these numbers are on top of the pistons in purple . The number on the pistons underside is 963P will this help me find out what type and who makes them the look like domed pistons not sure ill be posting pics as well
Old November 17th, 2014, 06:07 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
How does the Olds drive train line up? Never done a non GM swap. I love the Olds 350 but have heard the AMC was a very good motor. I know the dog leg heads with the heart shape chambers especially were better than the no quench Olds heads. Unfortunately AMC put the terrible Motorcraft carbs on them.
olds 307 and 403 is online now
Old November 17th, 2014, 06:55 PM
Never mind all of that stuff -- Put a Toro drivetrain in the back under the hatch!
MDchanic is offline
Old November 17th, 2014, 07:07 PM
Marshtonk's Avatar
motor is a 2.5 pontiac iron duke 4 cylinder with a chevy bell housing but i got a better deal on the olds engine thats why im swapping transmission also
Old November 18th, 2014, 01:10 PM
Marshtonk's Avatar
the engine stamping pad number is either 39M231004 or 32M231004
Old November 18th, 2014, 01:13 PM
It's 32M - a 1972 motor built in Lansing.
MDchanic is offline
Old November 18th, 2014, 01:18 PM
Marshtonk's Avatar
and how do you know it wouldn't be 39 i could just make out the second digit and so does that mean its a block with the windowed deal going on ?
Old November 18th, 2014, 01:25 PM
The windowed blocks for '79 have a different casting number on the top at the front (557265 instead of 385558).
MDchanic is offline
Old November 18th, 2014, 01:32 PM
Marshtonk's Avatar
ok so the block is ok then im just worried this guy put good money into not so strong of a block the good blocks are from what 68-72 then ?
Old November 18th, 2014, 01:55 PM
Marshtonk's Avatar
oh wait be cause 7A heads go on a 72duh ok we alredy discussed that [part sorry
Old December 18th, 2014, 02:15 PM
Eddie Hansen's Avatar
cool beans ...
Followingbalong inam assumingnthis will only be a 2wd version? Maybe it was only the spirit that had a 4wd option, doesnt matter following along
Eddie Hansen is offline
1BOSS83
December 21st, 2013 06:27 AM
Sampson
July 12th, 2013 04:58 PM
AirborneRME
Wheels and Tires
April 15th, 2013 08:12 PM
Joffroi
May 20th, 2012 03:00 PM
nukesec1
April 9th, 2010 06:31 AM
Quick Reply: 1982 AMC spirit getting 1971 Olds 350
