1967 frame off started
Old Jun 16, 2009 | 09:34 AM
greyghost's Avatar
I am not new to the site but finally am getting around to starting on my 1967 olds cutlass. I have been selling parts on here in the past from the 2 other parts cars that I did not need. I have a lot of pictures to post a big thanks to JChicago who has helped me out in the past with posting my pictures. I have the frame totally stripped down and it is going to be blasted and powder coated. It is nice to have access to all the old threads on here for advice. Thanks again and I will try to share some pictures soon. Don L.
Old Jun 16, 2009 | 12:59 PM
greyghost's Avatar
Hello again trying to get activated hopefully just a couple more posts.
Old Jun 16, 2009 | 01:00 PM
greyghost's Avatar
Hello still at it
Old Jun 16, 2009 | 01:01 PM
greyghost's Avatar
Hello almost there I hope
Old Jun 16, 2009 | 01:02 PM
Hang in there one of the smarter mods will get you moved out of Newbieville.
Old Jun 17, 2009 | 05:42 AM
greyghost's Avatar
Its raining in Ohio and still spring conditions, not all bad I guess.
Old Jun 17, 2009 | 08:18 AM
Oldsguy's Avatar
Past Administrator
Don, is everything working for you now? Do you have full access as a registered member now?
Old Jun 17, 2009 | 08:25 AM
greyghost's Avatar
I believe so it still says when I sign in that I do not have access to this page, is that normal? Thank you for your help
Old Jun 17, 2009 | 09:31 AM
Oldsguy's Avatar
Past Administrator
Ok, there is a general statement at the top of the newbie forum which refers to "you" in general as in anyone that is a newbie, not "you" personally. You are a registered member now. There is a chance you are getting a message when you (as in YOU) sign in but it may be an error when the forum loads. Omicron has a suggestion in that case which I always get turned around. Instead of logging in on the main webpage, log in on the forums webpage, or else it is the other way around. Regardless, if you can make posts in all forums, upload pictures, etc. then you are fully accessed to the site. If there is still trouble let me know or just PM omicron (Paul) as that is who I would refer this problem to.
Old Jun 17, 2009 | 09:33 AM
greyghost's Avatar
Ok Thank you for your help I will try to post some pictures this evening.
Old Jun 17, 2009 | 10:30 AM
wolfman98's Avatar
Captain of my ship
Same
It still does that to me but I just ignore it and click on Forums and it works fine.
Old Jul 11, 2009 | 05:17 PM
csstrux's Avatar
Moved this to major builds...Still waiting for pics, and an update.
jensenracing77
Nov 6, 2022 09:52 PM
sixty9olds
Jun 14, 2011 06:43 PM
Gary's 2 442-S
Nov 18, 2008 04:08 AM
Want-A-Vert
Mar 30, 2007 08:00 PM
DJMatthews
Dec 5, 2006 01:28 PM
