72 Supreme coupe rear 1/4 window inner weatherstrips
For a 72 Supreme 2 door coupe (H/O) Does anybody know if the rear quarter window inside weatherstrips are available from any source? I have found the outer. Thanks
Thank You! the old inside one that I still have looks like it slides into place with 3 clips. Installing the outer was a bear in this 92 degree heat here in Cincy. I'll check out that source you gave. Thanks again
Wait, are you talking about the vertical rubber seal along the back of the quarter window that attaches to the C pillar?
Fusick's sells the outer - OQW702
The inner is a problem. Keep your old ones, you have to modify Chevelle parts.
Here's what I ran into last year: https://classicoldsmobile.com/forums...-seals-125479/
AJFink
June 19th, 2018 07:50 AM
