72 Supreme coupe rear 1/4 window inner weatherstrips
Old July 10th, 2019, 01:44 PM
EdwardB's Avatar
For a 72 Supreme 2 door coupe (H/O) Does anybody know if the rear quarter window inside weatherstrips are available from any source? I have found the outer. Thanks
EdwardB is offline
Old July 11th, 2019, 06:45 AM
oddball's Avatar
Those are called inner sweeps. The best ones are from Restoration Specialties. Real PITA to staple on new ones.
oddball is offline
Old July 11th, 2019, 11:51 AM
EdwardB's Avatar
Thank You! the old inside one that I still have looks like it slides into place with 3 clips. Installing the outer was a bear in this 92 degree heat here in Cincy. I'll check out that source you gave. Thanks again
EdwardB is offline
Old July 11th, 2019, 12:56 PM
92 degree heat. That's just a few degrees above our overnight lows.
Fun71 is offline
Old July 12th, 2019, 06:39 AM
oddball's Avatar
Wait, are you talking about the vertical rubber seal along the back of the quarter window that attaches to the C pillar?
Fusick's sells the outer - OQW702
The inner is a problem. Keep your old ones, you have to modify Chevelle parts.
Here's what I ran into last year: https://classicoldsmobile.com/forums...-seals-125479/
oddball is offline
AJFink
June 19th, 2018 07:50 AM
tonycutlassw31
November 29th, 2013 07:51 PM
Indy Guy
October 15th, 2013 08:18 AM
1970cs
August 16th, 2012 11:30 AM
dhartley72
June 26th, 2010 12:48 AM
Quick Reply: 72 Supreme coupe rear 1/4 window inner weatherstrips
