Power vs manual bucket seat
Old Jan 30, 2024 | 12:26 PM
72455's Avatar
1972 U code Supreme
I have the 4 way power driver seat in my '72 Supreme and looking at getting a set of extenders. Are the seat bases the same whether it's a power or manual seat?
Old Jan 30, 2024 | 02:14 PM
If you mean they bolt down the same, yes.
Old Jan 30, 2024 | 03:08 PM
72455's Avatar
1972 U code Supreme
Ok thanks.
Old Jan 30, 2024 | 04:39 PM
2blu442's Avatar
I was thinking the power bucket had some extra support on the rear mount. Maybe three instead of two bolt holes. Will the extender need to bolt to both the front and back of the seat rails? John
Old Jan 30, 2024 | 05:07 PM
Loaded68W34's Avatar
By "base" do you mean the bottom of the seat or the mounts on the floor. The seat bottom is the same, but the later power tracks use different front mounting holes than the manual tracks. The rear floor mounts are completely different on a power seat. The power track rear floor mounts are several inches further forward than the manual track mounts.
In the photo below, the red circles show where manual tracks would bolt to the seat bottom. The green circles show where the power tracks bolt to the seat bottom.
In the photo below, the red circle shows where the rear mounting bolt would be on a manual track. The green circle shows where the rear mount is on a power track.
Old Jan 30, 2024 | 05:53 PM
72455's Avatar
1972 U code Supreme
I need to know if both the power and manual seats bolt to the floor the same, not where the base bolts to the bottom of the seat.
Old Jan 30, 2024 | 06:53 PM
I showed that in photo 2 in my post. The rear power seat FLOOR mounts are about 3" forward of the manual mounts. The outer rear mount is also 1/2" - 1" lower than the manual outer rear mount so it cannot be easily moved back.
Old Jan 31, 2024 | 06:29 AM
72455's Avatar
1972 U code Supreme
Is there anyone that sells the extenders for a power seat?
Oct 24, 2020 06:57 PM
Lucas Cowdrey
Mar 13, 2016 03:09 PM
neatolds
Aug 22, 2015 10:59 AM
Kid64
Jan 4, 2013 02:55 PM
Jonb442
Jan 11, 2010 12:46 PM
