I dont think this is right...
Old Mar 4, 2019 | 06:07 PM
72455's Avatar
1972 U code Supreme
Hello all ye Oldsmobilers 😀
I was working on my 72 Supreme last week and noticed something that didn't look right and also could be the reason why I'm having trouble with the door seal staying intact when I close the door.
Take a look at this pic and you'll see the "bead" that runs along the front of the rear interior panel is sticking out. My guess is that it's actually hitting against the door seal. Question is, how is supposed to actually be? The passenger side actually "rolls" inward and tucks underneath the panel and I have no trouble with the door seal on that side.
Thoughts and comments would be appreciated.
Dave
Old Mar 4, 2019 | 06:29 PM
PatL's Avatar
Dave, I can't see your picture
Old Mar 4, 2019 | 06:58 PM
70Post's Avatar
the bead should be tucked in under the panel as you mention BUT it also looks like the rubber "U jamb" piece is sticking out quite a bit. That screw and molding should be tightened down.
Take a better pic as well....maybe from a slight angle.
Old Mar 5, 2019 | 06:27 AM
TripDeuces's Avatar
Those screws are incorrect. Are the heads hitting anything? You could just trim that little bit hanging out on the seal but I doubt that's stopping the door from closing
Old Mar 5, 2019 | 09:10 AM
72455's Avatar
1972 U code Supreme
I trimmed the end off at an angle so hopefully that will take care of it. I wasn't having trouble with the door closing. The issue was the top of the door seal where it goes around the top of the door kept getting pushed out of place . I'll see what happens. In the meantime, if those screws are wrong, what ones do I need?
Old Mar 5, 2019 | 09:28 AM
442crzy's Avatar
The screws for the U shaped jamb seal require Phillips head screws, they will actually sink into the rubber jamb seal.
Old Mar 5, 2019 | 10:48 AM
Dave, the windlass is the original to the car? If so it's not been installed correctly. Much as I hate to say it, go back and reinstall the interior quarter door card, it's not seated properly. The trim screws for the door jamb seal are Phillips. Chances are you've over sized the holes with those self tapping metal screws. Look at the diagrams on page 13-10 and diagram 13-29 on page 13-15 of the 1972 Fisher Body Service manual. I suspect a PO has drilled other holes to attach the windlass trim, or it isn't secured at all like it's supposed to be.
Old Mar 5, 2019 | 07:16 PM
Originally Posted by Allan R
...the windlass...???
...is a type of winch.
I believe you to mean 'windless'.
Old Mar 5, 2019 | 07:23 PM
bccan's Avatar
Windlace
Old Mar 5, 2019 | 07:25 PM
Originally Posted by bccan
Windlace
Yeah, I forgot about that word. Good catch.
Old Mar 6, 2019 | 02:58 PM
Windlace
What I meant. Must be getting old...
VC455
Oct 5, 2017 07:48 AM
Rage3211
Sep 19, 2017 11:46 AM
Inline
Body work
May 1, 2016 08:52 PM
Macadoo
Jan 18, 2015 12:55 PM
kona0197
Mar 27, 2012 04:47 PM
