Incorrect door seal from Summit
Old Jan 18, 2015 | 09:53 AM
Macadoo's Avatar
I'm assuming this is not the correct seal. It doesn't even look close to me. And the other end (2nd picture) is even further from correct.
Package says:
LM 12-A
69-72 GM "A" Body 2 Dr Door Seal
Metro Supersoft
[IMG][/IMG]
[IMG][/IMG]
Or am I not understanding something here?
Old Jan 18, 2015 | 09:56 AM
Macadoo's Avatar
Here's a link to the Summit page:
http://www.summitracing.com/parts/mm...-style/hardtop
Old Jan 18, 2015 | 10:48 AM
66luvr's Avatar
The piece you have in your hand is for the door, in your picture I can even see the instructions telling you how to install on a door. The piece on the car, which you are comparing goes up the "A" pillar, which would be a "roof rail molding". This means those are different pieces and are not going to interchange.
Someone sent the wrong part or someone ordered the wrong part.
You can browse Metro stuff for your car, get part numbers and application information here;
http://metrommp.com/?f=product_list_...&Model=CUTLASS
Sorry for your bad luck,
Mike
Old Jan 18, 2015 | 11:13 AM
1970cs's Avatar
Lansing built
You need RR5503 Roof rail seals.
Pat
Old Jan 18, 2015 | 12:51 PM
Macadoo's Avatar
Mike
Uhhh......guilty as charged.
Wow, I didn't even see those on the door. Luckily (?) those are hard and worn as well. So uhh...yeah, I meant to make that mistake
Thanks for the info fellas. My only regret in all this is that I didn't just buy the kit. I replaced the trunk seal yesterday (easy peasy), and decided last night that I needed the quarter window seals as well. Oh well, I'll be out a few bucks but maybe if someone else reads this they won't make the same mistake.
Old Jan 18, 2015 | 12:55 PM
Macadoo's Avatar
Pat
Looks to be RR5003.
navvet
Jun 8, 2014 07:21 PM
Astrolink
Oct 18, 2013 05:39 AM
Creativeindy
Sep 10, 2012 12:21 PM
RyanFink
Jan 29, 2012 08:15 AM
Red Delta
Jan 2, 2011 11:18 AM
