Converting to power windows '77 Cutlass
Old Oct 23, 2023 | 08:36 PM
getmygoat's Avatar
Hi all,
I was wondering if when converting from manual to power windows, does the power window switch fill the "hole" in the door panel left by the manual window crank? e.g. can I avoid replacing the door panel ? I assume the driver side is certainly "long" enough to fill space horizontally, although height might still be an issue.
Thanks!
Old Oct 26, 2023 | 03:39 PM
joes_olds's Avatar
I did this on a 76 supreme. The switch does cover the hole, the back side on my 76 had a pattern to cut out for the switch.
In my case however, the door panel was slightly abused and you could see a wear pattern from the window handle. It didn't bother me much so I left it as is
extreme_442
Oct 1, 2019 06:32 PM
slantflat
Non-Olds Engines
Nov 20, 2012 12:00 PM
yeahbuddy
Jun 24, 2010 02:22 AM
real442
Mar 8, 2008 07:03 PM
rustycarr
Mar 7, 2007 06:24 AM
