No power to windows or top
Old Oct 1, 2019 | 11:44 AM
extreme_442's Avatar
Good Day Everyone,
I have a 72 442 convertible.
At present I don't have any power to my top or power windows.
The breaker in the fuse panel has power on both sides but from there I am having trouble figuring out where to look next.
Any help would be appreciated.
It started out that I was putting in a new power window motor, then portion of the harness and then the switch on the driver door to control all 4 windows.
Everything is connected and can't see that there are any blown fuses anywhere.
Regards,
Ken
Old Oct 1, 2019 | 04:17 PM
Dave26's Avatar
If I were a betting man, I would look for a short that is tripping the 40 amp breaker....re-check all of your new wiring, connections etc....test the breaker, make sure it’s re-setting.
Old Oct 1, 2019 | 06:32 PM
Did you check the accessory power isolation relay? Hint: the wiring diagrams for the power windows and top are in the Fisher Body Manual.
mooner
Sep 4, 2019 05:35 PM
Olds luvr
Mar 19, 2015 09:34 AM
slantflat
Non-Olds Engines
Nov 20, 2012 12:00 PM
squirell
Apr 13, 2011 05:22 PM
Beob
Feb 5, 2010 10:09 AM
