Cardboard headliner in 68
Under the factory headline on my 68 is a cardboard piece that is glued to the ceiling. It's wet and extremely soft. Rubbing your finger with pressure will scrape it off.
It is complete and I am going to be applying sound deadening material. Question is do I need to scrape all off the cardboard first?
It is going to be messy as heck and probably has asbestos. What do you guys do when dealing with the ceiling/roof?
soak it with a spray bottle, then scrape it out with a wide puddy knife.
wetting it will keep it all from getting airborne and into your nose, and also keep it together better for removing in large chunks.
I used a box knife and cut it where it goes between the roof supports and the roof skin and left those chunks in place, removed the rest.
Then prep and install modern sound deadening onto the roof panel.
Its a nasty job, but there is a massive difference in sound deadening after putting modern stuff on it. I used the summit house brand which i read someplace is made by hushmat. I've worked with dynamat before and felt it was pretty equivalent for a lot less $$
Wow. Removing the old glue/tar and cardboard or whatever it is has been a PIA! I spent 2 weekends on it and I still need another weekend to get it fully prepped.
I spent 1 weekend scraping off the cardboard/insulation with a putty knife. It made a HUGE mess but most of it was contained on the tarp I threw down.
This weekend I started using a wire wheel and my drill to get rid of the cardboard residue. I am halfway done but there is still another black tar/glue layer but it is starting to show tiger stripes with the bare metal undernieth. Any suggestions on how to get the black glue off? I was thinking of getting a wire wheel for my angle grinder and get rid of the drill but I dont want to damage the metal.
olds70supreme
February 23rd, 2020 06:02 PM
jurrasicpork
June 25th, 2019 10:03 AM
