1984 Oldsmobile Delta 88 seats
Old Oct 22, 2019 | 08:46 AM
Darkolds84's Avatar
Hello All, i am looking to swap out the 60/40 front seats of my 84 Delta 88 (b body) to Bucket Seats since i Autocross the car. i am wondering if anyone has done this before? if there are Brackets that i can use to install the new seats? or if i can dismount the seats from the original brackets and attach my new seats to those? or if the mounting from a g body would work for the b body? any information would be great.
Old Oct 22, 2019 | 08:58 AM
Bucket seats were available in the 78-81 Holiday 88s. Those wouldn't be much more suited to Autocross than your 60/40 bench seat though. Even bucket seats from an 80s Cutlass wouldn't be that appropriate for Autocross. I suggest you buy aftermarket seats and make them fit in your car. Make sure you add gussets to the floorboard where you attach the seats. It wouldn't do you much good to just drill a hole and use a bolt/nut.
Old Oct 22, 2019 | 09:06 AM
Darkolds84's Avatar
i actually have a set of bucket seats just trying to do some research before i attempt to install them
Old Oct 22, 2019 | 10:13 AM
Are the buckets from a Cutlass? If so, I doubt they would fit in your Delta 88 without modification.
Old Oct 22, 2019 | 10:26 AM
Darkolds84's Avatar
they are aftermarket bucket seats, they were installed previously in a Monte Carlo but they do not have brackets, my thought originally to modify the existing seat frames to accept the different seats
Old Oct 22, 2019 | 11:11 AM
If you modify the seat frames to fit the aftermarket seats you can be sure everything will fit properly. Just don't change the way the bracket bolts to the floorpan. Also, you would want to make sure you don't weaken the seats if they need modification.
Old Oct 22, 2019 | 11:14 AM
The 64/40 bench uses the same floor pan brackets and seat tracks as do the buckets.
washqueen
Nov 3, 2015 06:51 AM
zk194
Oct 11, 2013 11:10 PM
yamahondarider
Oct 7, 2013 07:43 PM
bonezarally
Jul 9, 2013 05:54 PM
Drowe44
May 12, 2012 12:20 PM
