1970 cutlass dash mounting HELP!
Old Jan 4, 2022 | 07:46 PM
matviar's Avatar
I am ready to install the dash back on the car. There are about 8 to 10 studs that go into the metal dash . I lost the mounting nuts. I tried using 8-32 but wont start onto the studs. The threads look ok . Does anyone know if these were supposed to be speed nuts or what?
Old Jan 4, 2022 | 08:17 PM
70Post's Avatar
Speed nuts (aka "stamped nuts") were used there.....8 - 32 size.
Old Jan 5, 2022 | 01:48 AM
matviar's Avatar
Thanks for Your help Patton.
Old Jan 5, 2022 | 09:55 PM
70Post's Avatar
If you can't find any speed/stamped nuts that work just let me know and I can send some to you. I probably have plenty around here.
Old Jan 6, 2022 | 06:27 PM
matviar's Avatar
I have 5 new ones. I'll check the local ace hardware. If They don;t have them. I'll check back I only need 3. Thanks!
Old Jan 6, 2022 | 10:17 PM
70Post's Avatar
PM me w/your info/address if you end up needing some and I'll send them over. No payment needed.
Old Jan 8, 2022 | 03:43 AM
matviar's Avatar
Hi Patton. They didn't have them at Ace. I need 5 of the speed nuts. I will PM. Thank You!
Old Jan 4, 2026 | 02:59 PM
1970Slutlass!'s Avatar
Nuts for your dash
I just pulled out my dash. if the fastener are a 8-32 serrated self locking nut. Bolt Depot has them https://boltdepot.com/Product-Detail...IaAnVAEALw_wcB Do you know where to find the entire threaded stud? I have been digging as a couple of mind are screwed up. See photo
Old Jan 4, 2026 | 04:09 PM
cdrod's Avatar
Rodney
I used serrated nuts like the ones in this pic, when I reinstalled my dash. They worked just fine.
Rodney
Old Jan 5, 2026 | 06:17 AM
oddball's Avatar
I doubt those are readily available. If they are then I would expect Auveco would have them - dig up one of their catalogs on the internet then go searching for the part number.
The easiest answer is probably posting a parts-wanted ad here. I bet someone would send you a few for a song.
gratsoy
Sep 24, 2021 08:55 PM
w30brad
Feb 8, 2020 02:41 AM
rickbmac
Jul 16, 2016 04:27 AM
HOT-SHOT10
Aug 14, 2011 04:48 AM
DJMatthews
Dec 12, 2006 06:36 AM
