convertible top fluid
Old July 11th, 2017, 01:21 PM
x55racer's Avatar
How do I add fluid to the convertible top pump on a "71 Cutlass Supreme?
x55racer is offline
Old July 11th, 2017, 03:08 PM
Locate the pump in the trunk behind the back seat. Remove the rubber plug in the end of the reservoir. Fill.
joe_padavano is offline
Old July 11th, 2017, 03:26 PM
71 cutlass convertible
lshlsh2's Avatar
A turkey baster works for filling the pump. I would buy a new one, using your wife's out of the kitchen could get you into a little trouble.
lshlsh2 is online now
Old July 11th, 2017, 04:26 PM
Tedd Thompson's Avatar
Or a ketchup/ mustard bottle as found at your local diner with a 2 foot length of 1/4" clear plastic tubing and a bunch of towels stuffed around the motor area so when you over fill it you won't make a mess.(don't ask me how I know).... Tedd
Tedd Thompson is offline
Old July 11th, 2017, 06:25 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Good tips there Tedd. It is a messy job. I don't think anybody mentioned to use ATF to fill the pump. DO NOT use brake fluid since it will eat paint if it gets on it.
redoldsman is online now
Old July 12th, 2017, 07:14 AM
And if it has brake fluid in it now you gotta get it all out before you add ATF. I doubt that they were using brake fluid as late as 71 but check it out or you will have a mess on your hands.... Tedd
Old July 18th, 2017, 07:47 PM
x55racer's Avatar
Thanks for the info, guys. I knew about the turkey baster and using ATF, I just didn't know where the fluid went in. And I'll be sure to buy a new one! Don't want to be sleeping in the garage with my car.
x55racer is offline
Old July 18th, 2017, 08:32 PM
m371961's Avatar
I dunno, if I ever finish my seats, I might do just that.
m371961 is offline
Old April 9th, 2020, 10:24 PM
"I reckon so!"
RATCHETMASTER's Avatar
Yep.
RATCHETMASTER is offline
Old April 10th, 2020, 04:19 AM
When I reupholstered my interior I found my left cylinder was leaking all over on the floor. One thing led to another and next thing you know another project! Anyway if it just got low you may want to check out why before you have a big mess.
Greg Rogers is offline
GoBigRed
Brakes/Hydraulic Systems
15
October 5th, 2015 01:00 PM
MudEye
December 21st, 2011 10:52 AM
squirell
June 30th, 2009 08:56 AM
cfair
June 8th, 2009 12:37 AM
70redvert
December 22nd, 2007 04:53 PM
Quick Reply: convertible top fluid
