Where do these bolts (copper?) go?
Old January 5th, 2012, 06:40 PM
oldzy's Avatar
Anyone recognize these bolts? Seem to be copper plated or something. Was looking through a small pile of bolts and can't recall where they were from. I think they are from the dash (or interior at least) area, since they were with related bolts/screws.
oldzy is offline
Old January 5th, 2012, 07:07 PM
They are copper shear bolts that hold the bracket to the bottom of the steering column.
There should be four of them, if I recall.
Two steel studs and flanged nuts hold the same bracket to the dash.
MDchanic is offline
Old January 5th, 2012, 07:19 PM
oldzy's Avatar
Thx. I need to check my margarine container again for the other two. I also need to find that bracket, since it is related to the below part which goes above the steering column... so I can paint/plate them.
oldzy is offline
Old January 5th, 2012, 07:45 PM
Yes, if I'm not mistaken, the studs for the bracket go through the two holes in the far left of the large rusty bracket you've got there.
MDchanic is offline
Old January 5th, 2012, 08:44 PM
oldzy's Avatar
Yes, they do (those long rusty studly things).
One of them had a thin speed/retainer type nut on the threads. Not sure why since there are two bolts that go on anyway. It was also 'above' the column against that big rusty part shown above... so it was not like it was holding/retaining the column at all.
oldzy is offline
Old January 6th, 2012, 04:33 PM
2blu442's Avatar
Here's the bracket on a parts car. The four copper bolts seem to have rust on them! If you need this bracket and two more bolts let me know. I've got a bunch of extra columns in the rafters of my garage. I know I can come up with some in nice condition. John
2blu442 is online now
Old January 10th, 2012, 06:36 PM
oldzy's Avatar
Thanks for the pic. I found my bracket. There a few things I am wondering about. First is why they used copper plated bolts. Second... there is some sort of oozing yellow stuff around those aluminum mounting things. Third... there was some hard dark sticky stuff (oh my) on the inside of those alum things as well.
oldzy is offline
Old January 10th, 2012, 07:07 PM
They used the copper screws and the glued-in holes because the bracket is designed to break off.
In the event of a head-on collision, the driver would strike the steering wheel, which would push the column forward, breaking off the plastic pins in the shaft on the firewall side, thus allowing that portion to telescope, and shearing off the copper screws, and pushing that bracket forward, breaking the bond of that yellow plastic, and coming away from the dashboard.
Beats the heck out of being speared through the heart by an old-style non-telescoping column, but I'd still rather be punched in the chest by an airbag if I had my choice.
MDchanic is offline
nolabigdawg
October 25th, 2014 11:50 AM
NHolds
Brakes/Hydraulic Systems
April 10th, 2013 03:53 PM
bumbi
Paint
November 29th, 2011 10:14 AM
fmbjogger
November 18th, 2011 05:00 AM
jkoester122
September 8th, 2011 07:48 PM
Quick Reply: Where do these bolts (copper?) go?
