Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Need help identifying name of metal hose on top of water pump; 1989 chevy corsica 2.8
Old May 12, 2024 | 05:20 PM
Joeykaza's Avatar
2.8 v6 engine i have no idea what this hose is called it has coolant leaking out of it the slightest bit and it wanting to buy a new one but have no idea what to look up to find it
Old May 12, 2024 | 05:24 PM
Joeykaza's Avatar
what is this coolant hose called?
its located to the right of the water pump and has a hose leading to the right side of the engine under the MAF, i got into an accident a few weeks ago and have been replacing stuff and its slightly damaged and leaking a bit of coolant
Old May 12, 2024 | 05:32 PM
Is this an American made automobile model? What year(s) were they made and who made them?
Old May 12, 2024 | 05:34 PM
Joeykaza's Avatar
it’s a 1989 chevy corsica v6 2.8l, also sold in canada as a pontiac tempest they were made 1987 thru 1996
Old May 12, 2024 | 05:45 PM
Joeykaza's Avatar
man i just wanted to know what the metal hose is called so i could replace it u don’t gotta be an ***
Old May 12, 2024 | 05:52 PM
Which color represents what you're supposedly referring to? YELLOW, GREEN or PURPLE?
Old May 12, 2024 | 05:56 PM
Joeykaza's Avatar
green and purple are the same hose and the one i’m talking about the only METAL hose that’s there
Old May 12, 2024 | 06:32 PM
tru-blue 442's Avatar
Old School Olds
Good luck. I don't even show it in any info that I could find. You may be able to pull it, find a radiator guy to plug the hole. I have a good dist. for an 86 2.8 if you need one.
https://parts.folsomchevy.com/v-1989...and-components
Old May 12, 2024 | 06:37 PM
Joeykaza's Avatar
bet i’ll keep you in mind thanks man
Old May 12, 2024 | 07:02 PM
VI Cutty's Avatar
You may have better luck getting answers on a Chevy oriented site vice an Oldsmobile specific site...
Old May 13, 2024 | 04:53 AM
x2 on asking a radiator shop if they can fix the coolant pipe. If you can't find a shop willing to repair the part you can use this search engine to find another Chevy Corsica in the salvage yard near you.
http://www.car-part.com/
Old May 13, 2024 | 05:20 AM
Oldsguy's Avatar
Past Administrator
I might make a guess by it's shape and location that it is supposed to act as a valve either to allow coolant to flow through or not. Maybe it is called a thermostat. My wife's Dodge engine had two of them, they shared the same plastic housing and controlled two different circuits in the engine. Maybe the same for yours.
Old May 13, 2024 | 07:50 AM
Oldsfan's Avatar
That is a coolant bypass pipe. Long discontinued from GM. Part # was 10100056.
Joeykaza
May 12, 2024 05:34 PM
oldsrush
Jun 28, 2023 08:48 AM
Biggwaukegan
Nov 15, 2017 09:39 AM
Driftr
Oct 4, 2011 08:57 AM
