This ain't right
Old Oct 3, 2011 | 11:18 AM
Driftr's Avatar
My co-pilot for 30 years
This ain't right
Pulled water pump as it started leaking right when the weather got nice....found these bunched up in the throat of the inlet side. I can only imagine they are the remnants of the reinforcement springs inside the hose but NEVER expected to see them in this shape. Before just going ahead and replacing the water pump, anything I should do/ have done? Forgive my ignorance and thanks in advance for any help/hints/guidelines.
Old Oct 3, 2011 | 11:32 AM
DJS70cutlass's Avatar
I'd get all of it that you can see and call it a day. You should be just fine
Old Oct 3, 2011 | 03:48 PM
jag1886's Avatar
Don't forget a new bottom hose.
Old Oct 3, 2011 | 05:31 PM
Redog's Avatar
I was thinking the same things
Old Oct 4, 2011 | 07:01 AM
Driftr's Avatar
Thanks guys
Old Oct 4, 2011 | 07:22 AM
Eddie Hansen's Avatar
I would also shine a light down into the radiator making sure no little pieces are clogging any of the tubes... Just thinking out loud....
Old Oct 4, 2011 | 08:57 AM
chequenman's Avatar
Exclamation
Old worn out, out dated Antifreeze caused the spring in your lower Rad hose to rust like that, so you should flush your system, change your water Pump, install a new lower Rad hose as previously suggested, get a long life Anti-Freeze mixture and you should be good to go.....
Dead Reckon
Feb 13, 2015 09:11 AM
Octania
Jan 7, 2014 02:19 PM
edzolz
Nov 13, 2013 07:34 PM
jaunty75
Jun 7, 2013 01:57 PM
jugdish
Aug 9, 2010 09:22 PM
