Bypass hose on tripower engine?
Old Jun 22, 2023 | 07:07 PM
oldsrush's Avatar
Gearhead
Is the bypass hose down to the water pump different for a tripower engine compared to one with just a 4bbl? Which nipple on the water pump does it normally connect to?
Old Jun 22, 2023 | 08:15 PM
66-3X2 442's Avatar
Absolutely different. The hoses are swapped/crisscrossed on the water pump for the tri carbs. Fusick has the correct repo hose.
Old Jun 22, 2023 | 08:17 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Yes, The Tripower hose actually connects to the heater nipple. So it's significantly longer vs the regular 400 L-shaped hose.
edit<66 beat me to the punch>
Tripower:
Standard bypass:
Old Jun 23, 2023 | 09:28 AM
oldsrush's Avatar
Gearhead
Thanks guys!
Old Jun 28, 2023 | 08:48 AM
oldsrush's Avatar
Gearhead
Should have realized it before now but the top radiator hose is different for a tripower setup also.
v8al
Tech Editor's Desk
Mar 26, 2021 10:06 AM
79MKII
Jun 4, 2013 06:23 AM
matviar
Apr 9, 2012 12:56 PM
ralsy
Jul 24, 2011 05:36 PM
