use factory resistor wire to trigger relay for HEI
Old Mar 26, 2014 | 01:54 PM
72cuttys's Avatar
Can I use the factory resistor wire to activate a relay and just send 12v directly to my HEI from the battery? If not, what is a good spot to tap into to get 12v keyed?
Found this diagram, however it is for a GTO and I dont not know if they used the same points setup as the olds.
Old Mar 26, 2014 | 01:59 PM
That will work. The points setup is the same as an Olds.
Old Mar 26, 2014 | 02:14 PM
jensenracing77's Avatar
X2, It will work but why not just go from the ign terminal on the fuse box? Those relays are fairly reliable but you're relying on the relay to get you home.
Old Mar 26, 2014 | 02:16 PM
I guess you could keep an extra in the glove box
Old Mar 26, 2014 | 02:47 PM
4speed455's Avatar
X2 on running a new wire off the IGN spade on the fuse block. You will have to run a 12v wire to that relay anyways. Why not do less work and use less money/parts.
I actually have a M&H engine harness set up with the proper wiring and connectors for an HEI distributor and internally regulated alternator. Mine needed to be replaced and I was able to order to my specs. It looks identical the factory harness except for the mods.
Old Mar 26, 2014 | 03:33 PM
jag1886's Avatar
Yes you can, I did this on my 65, I just removed as much of the original wire as possible and replaced it with regular wire, works perfect and you won't have some cobbled up looking wiring coming through the firewall.
Old Mar 26, 2014 | 03:36 PM
jag1886's Avatar
You are missing the point of the relay, you can run a 10 gauge wire direct from the horn relay to supply power to the ignition when you use a relay, this makes for a very reliable power supply for an HEI instead of trying to suck the power off what is sometimes an overtaxed stock fuse box.
Yes I do carry an extra in my tool box right beside the replacement HEI module.
Old Mar 26, 2014 | 04:03 PM
If you are looking for a more direct power source I can understand but how much amp draw does an HEI coil have?
Old Mar 26, 2014 | 04:11 PM
If the relay fails, all you have to do is jumper terminals 30 and 87.
Old Mar 26, 2014 | 05:00 PM
dmullin's Avatar
azure blue 442
horn relay stand off
Your relay idea will work fine. I've had a similar set up on my 70 442 for years.
However, if you are sourcing power from the horn relay stand off, use 10 gauge wire to the relay and from the relay to the coil/module connection.
I suggest a 25 or 30 amp fuse.
14 gauge wire will lose some voltage ,while #10 won't at these current levels and wire lengths.
Also, be sure to buy a minimum 30 amp relay of reputable quality. It will last longer, and have less voltage drop across the internal contacts.
Happy wiring.
Old Mar 26, 2014 | 05:48 PM
72cuttys's Avatar
All this mention of using the horn relay for a source, what is wrong with just using the battery?
Old Mar 26, 2014 | 05:56 PM
dmullin's Avatar
azure blue 442
There isn't anything wrong tapping off the battery if you fuse it close by.
But the horn relay stand off is intended for branching from, and its closer, neater and also comes from a fusible link source.
Old Mar 26, 2014 | 06:05 PM
72cuttys's Avatar
Im not currently around my car, where is the horn relay stand off?
Old Mar 26, 2014 | 06:11 PM
dmullin's Avatar
azure blue 442
On most older cars it would be on the firewall, on my 70 442 it is on the inside of passenger fender. Just above the inner fender mounting lip.
Old Mar 27, 2014 | 12:30 PM
72cuttys's Avatar
Will the horn relay provide 12v while cranking? Or do i need to use the starter wire for that.
Old Mar 27, 2014 | 02:51 PM
It is 12 volts all the time. Runs from the battery to the terminal, nothing between.
Old Mar 27, 2014 | 02:55 PM
What determines 12v during cranking are the 2 wires that used to be on the coil positive terminal of your original wiring. There is the resistor wire and the wire provided for the bypass circuit from the starter. In your drawing they are connected to terminal 86 on the new relay.
Old Mar 28, 2014 | 08:02 AM
RAMBOW's Avatar
Ben
This is what I've done on several cars- just cut it back to the minimum length you can safely work with by the connector- strip, then solder on a new wire, cover with heat shrink. Always gotten the full 12 volts afterwords.
Old Mar 28, 2014 | 10:20 AM
72cuttys's Avatar
I found it, I see what you are saying. I thought you were saying to use the horn relay as a switched 12v source.
I took the carb off last night, might swap my HEI while I have easy access to the dist.
Old Mar 28, 2014 | 01:32 PM
I measured mine several yeas ago using a Fluke 189 multimeter in Fast Min/Max mode and the highest reading was just over 5 Amps. I am not 100% certain I was able to capture the peak values with this method, though.
Old Mar 28, 2014 | 02:41 PM
jag1886's Avatar
You guys are still missing the point of the relay, it has nothing to do with what amperage the ignition is pulling and has everything to do with how much amperage everything else added together is using.
What I mean is you are driving at night with the air on, blower motor on high headlights on high beam and stereo running full blast, that's when that old fuse box is being seriously overtaxed. When you have a stand alone ignition system it has a better chance of not having a voltage drop that could harm something.
Am I making any sense?
Old Mar 28, 2014 | 02:49 PM
Exactly, with the relay, your ignition load is not going through the cars electrical system. Your guaranteed full battery voltage to the ignition at all times.
Old Mar 28, 2014 | 03:04 PM
I missed nothing; I was simply answering the question that was asked.
And are you certain that the fuse box is being "seriously overtaxed" in that situation? I have been there many times and nothing catastrophic happened.
Old Mar 28, 2014 | 04:14 PM
dmullin's Avatar
azure blue 442
40 year old electrical system
Hei ignition systems are designed to run at full electrical system voltage.
The electrical system designed for the original ignition will make the hei operate, but at what level?
Electrical loads don't really pull current. A given voltage will push a given current through a given resistance.
Therefore, if extra resistance is added to the primary ignition circuit by factors such as switch contacts, fusebox and bulkhead connections, in many cases 16 gauge wire and corrosion, you will have an operating voltage drop that induces less secondary current. Less spark.
My point is that by installing a higher output ignition you are requiring more out of the supply circuit than was originally designed for, that's before we account for all the aged parts.
joepenoso
Jun 4, 2014 01:56 PM
Mr Nick
Jul 4, 2013 10:02 AM
Mak
May 28, 2013 04:46 PM
Beob
Feb 11, 2011 06:38 AM
Flye
Jul 7, 2009 08:21 AM
