Steering wheel lock
Old Jul 23, 2013 | 06:41 PM
gearhead1218's Avatar
Steering wheel lock
How hard is it to disable on a 70 Auto column so that the wheel does not lock when shut off and key removed?
Old Jul 23, 2013 | 07:12 PM
Pretty easy - just remove the lock plate.
Old Jul 24, 2013 | 07:36 AM
I think the lock plate holds the cancel cam in place, or at least acts as a spacer. You could also remove the lock pin that engages the lock plate instead.
Old Jul 24, 2013 | 07:38 AM
Hmmmmm... Maybe it does.
But, yeah, the pin comes out, too.
Not hard at all.
Old Jul 24, 2013 | 06:50 PM
Knew that lock plate removal tool would come in handy.
So, pull the lock plate, remove the pin, reassemble and I should be golden.
Old Jul 24, 2013 | 07:49 PM
Sounds good to me, but I will note that I have never actually removed the lock pin, so I can't swear that there will be no side effects.
Old Jul 24, 2013 | 09:23 PM
1971cutlas's Avatar
steering lock feature
Just wondering what the reason would be to disable this feature??
Old Jul 25, 2013 | 06:18 PM
I'm putting in a B&M shifter. The B&M linkage that goes on on the tranny won't allow the additional rod from the column that prevents you from locking the column in gear.
So by disabling the lock, it'll be like you have a stick=shift column. While driving down the road and you stupidly shut off the ignition, you still have control of the car.
Old Jul 25, 2013 | 06:39 PM
starfire's Avatar
Do you do that a lot?
Old Jul 25, 2013 | 07:00 PM
+1. This seems to be a solution to a non-problem.
Old Jul 25, 2013 | 07:10 PM
It's very easy to simply weld the tab from the floor shift bracket to the existing column shift bracket, thereby making something similar to what the factory used on floor shift cars.
Old Jul 26, 2013 | 06:49 PM
And I would never want to see it happen.
Old Jul 26, 2013 | 06:56 PM
Was looking at that option Joe. May revisit it also. I doubt my skills at pulling it off though. Mostly my welding skills. Would have to farm out that one.
Unfortunately I'm starting to get to "that point" where I'm getting to the end of the money tree on this project. Thinking that disabling the lock will be the least expensive fix.
Old Jul 28, 2013 | 06:25 PM
OK Joe, looks like you are right again. I'm going to pluck a few leaves off that money tree and have that linkage fabbed up. I'll post a picture when done.
Old Jul 29, 2013 | 06:51 AM
Can I send this to my ex-wives?
Old Jul 29, 2013 | 06:41 PM
Careful, they may be your exes for a reason.
Old Jul 31, 2013 | 06:36 PM
OK everyone. I won't need to disable the lock on my column.
This is what I have ended up with.
Old Jul 31, 2013 | 06:45 PM
Pretty.
Old Aug 1, 2013 | 06:16 AM
Looks good. Where is the adjustment? The factory bracket has a slot for adjusting cable length. I assume the bracket on the pan has the adjustment in your case?
Old Aug 1, 2013 | 05:57 PM
Correct Joe.
goldie442
Aug 21, 2015 11:01 AM
benjamin247
Oct 1, 2014 07:23 PM
Maverick
Apr 22, 2014 05:04 AM
randomarrival
Dec 22, 2012 12:28 PM
Gary's 2 442-S
Apr 25, 2010 05:29 PM
