Oil pan bolt -what?
Old Oct 12, 2015 | 10:40 AM
Luch's Avatar
Oil pan bolt -what?
Anyone ever see this style of oil pan plug/cap? How the hell do I get it out of there? One surprise after the next here on this 394!
Thanks!
Old Oct 12, 2015 | 11:00 AM
rustyroger's Avatar
'87 Delta 88 Royale
Looks like a multi spline fitting to me. I've only seen them in metric sizes though.
Roger.
Sugar Bear's Avatar
Luch,
Standard plug for those cars. Have heard there is a special tool but have never used one. The square drive end of a 1/2" ratchet by itself (no socket) or a short 1/2" inch extension on a ratchet will work like a charm.
Better hope the distributor doesn't turn when you turn the drain plug
Old Oct 12, 2015 | 12:38 PM
2blu442's Avatar
Here's a thread from a few years ago discussing this. The old thread also has details on the specialty tool. But if you don't have one Sugar Bear is right, a 1/2 inch ratchet will do the job. John
https://classicoldsmobile.com/forums...l-pan-nut.html
Old Oct 12, 2015 | 03:48 PM
therobski's Avatar
X2 SugarBear, just turned my loose to change oil and filter with a ratchet! (no socket required)
Old Oct 12, 2015 | 08:14 PM
nsnarsk65cutlass's Avatar
That,s the same as on my 65 330,1/2 drive extension works perfectly.
Old Oct 13, 2015 | 09:22 AM
D. Yaros's Avatar
A tool was made to fit this drain plug, but as noted, a 1/2" ratchet works just fin.
Old Oct 19, 2015 | 12:09 PM
Luch's Avatar
Everyone here is really a big help, the 1/2 inch ratchet did the trick! I am guessing the previous owner never figured that out...and prior to that who even knows the last oil change! The filter I removed just looks like an old one to me. Could be a generic Jiffy Lube style for all I know but it just has an old sort of writing to it that I have never seen. Whenever that was hanged I bet is the age of the old oil!
Either way it's done and I am off to some cruising around...been running great since the full tune up!
Chris
Redog
Oct 20, 2015 03:29 PM
AzChevs
Oct 19, 2014 09:03 PM
AzChevs
Oct 8, 2014 10:13 AM
defiant1
Aug 12, 2014 04:43 PM
