Fuel pump W-30
Old Jul 20, 2010 | 11:41 AM
tim72's Avatar
Fuel pump W-30
By mistake I found that the W-30 had a bigger bowl fuel pump than the stock 350,455. Does any body know if the Fuel pressure it puts out is the same as stock?
Old Jul 20, 2010 | 02:12 PM
My442's Avatar
Airtex 40736
Go to their website - they list specs.
Old Jul 20, 2010 | 02:52 PM
svnt442's Avatar
I don't see why the pressure would be any higher. It's still designed to feed a Q-Jet carb.
Old Jul 20, 2010 | 03:11 PM
BlackGold's Avatar
The limiting factor for fuel pressure when using a Quadrajet is the area of the needle and seat. Too much pressure will blow the needle off the seat and flood the carb. I believe (but am not certain) that the W-30s used the same needle and seat as other Quadrajets of the same year. So they could not run any higher fuel pressure. If in fact the W-30s used a larger needle and seat (a common performance improvement), they might technically need a lower fuel pressure (though I think there's enough margin with stock pumps that you don't have to worry about it).
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
mefirst72
Feb 10, 2013 06:37 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
sshriber
Mar 22, 2010 06:16 PM
