front coil springs
Old Oct 31, 2009 | 06:30 PM
john suder's Avatar
front coil springs
could some one tell me how to get the springs compressed. I have tried to use two diffrent types of spring compressors. With out doing anny good. If sombody could help me I would be very thankfull.
Old Oct 31, 2009 | 08:10 PM
jensenracing77's Avatar
i think the book showed a long bolt going down through the top shock hole in the frame down to a large washer under the lower A arm and screwed the A arm up till it compressed the spring enough to get the A arm bolts in. i don't know what size bolt it is or how long it is.
Old Oct 31, 2009 | 08:45 PM
MX442's Avatar
I've used an internal spring compressor before with no problems.
I pulled out a set yesterday by just using a jack. I dropped a 3/8" rod of all thread through the shock hole all the way to the floor, just in case. I left the spindle attached to the upper arm, and released the lower arm, and lowered the jack. With the end link and the spindle still there, I figured it would hold the spring back if it came out. When it came out, the rod did its job of holding it in place. It is much easier to use an internal compressor to put them back in.
Old Nov 1, 2009 | 04:39 AM
john suder's Avatar
My car is a 1969 Cutlass S. The shock can not be removed without taking off the spring. I dont see anny way of getting it out ove the way. So that I can use an inside spring compresser.
Old Nov 1, 2009 | 04:53 AM
Nilsson's Avatar
You need to get a chassis service service manual before you proceed any further. The shocks are simple to remove the springs are a different story. Again get a manual before you get yourself hurt.
Just my .02 take it for what it's worth.
Old Nov 1, 2009 | 05:31 AM
X2. you must be careful with these springs. i seen one go through a garage door. well i seen it an hour after it happened. after they told me what they did i could have warned them if i were there.
Old Nov 1, 2009 | 07:11 AM
MX442's Avatar
It wasn't converted to coil-overs, was it?
Otherwise, you have to remove the shocks first. Later I can scan the service manual showing how they do it, but you'll need the special service tool. I don't know where to find one. I've tried putting them in this way, and I could never get the lower a-arm bolted back in.
The ones I did Friday wouldn't work that way either because the headers are blocking the a-arm bolts from coming out. They had to be done from the spindle side.
Old Nov 1, 2009 | 08:11 AM
john suder's Avatar
I am going to take the lower a arm to work. And open one end of the hole .125th. T his should allow me to take the shock in and out from the bottom. This shoule allow me to use the inner compresser. Dont know but I am going to try it.
Old Nov 1, 2009 | 10:53 AM
The shock MUST be removed first. I suspect you've tried to remove the two bolts that hold the bottom of the shock to the lower control arm and they just spin, right? This is common - the sheet metal clip nuts will snap if the bolt is rusted to the nut. Use either a torch or a cutoff wheel to remove the bolts, then get new bolts and clip nuts. With the shock out of the way, the internal compressor works fine.
Old Nov 1, 2009 | 11:34 AM
john suder's Avatar
The hole in the bottom of the aframe is 1.725. And the shock is 1.850 o.d. The shock will not come out the bottom of the aframe. Al of the bolts are off. I have all ready ground off the bolts.
Old Nov 1, 2009 | 05:09 PM
Bluevista's Avatar
Registered
I know the '64-'67 GTO had a smaller hole in the lower control arm for shock installation.
Replaced at some point with the older style ones?
It sounds like opening up that hole is the easiest and best solution.
If you're taking the control arm to work to enlarge the hole does that mean the springs aren't in the car now?
x2 on the internal spring compressor.
Old Nov 2, 2009 | 01:21 PM
Well, I have no idea how that was put together. It's definitely not stock.
oldzy
Suspension & Handling
Mar 2, 2011 08:40 AM
defiant1
Mar 18, 2010 06:43 AM
Flye
Jun 12, 2009 01:21 PM
veltboy618
Mar 26, 2009 08:27 PM
mcutlass1969
Aug 6, 2006 03:47 AM
