Exhaust Manifold flapper
Old Mar 25, 2019 | 02:15 AM
68cs's Avatar
I have a very squeaky flapper assembly that is driving me insane on the drivers side exhaust manifold. This thing is noisy.
Any reason that I shouldn't just wire it open which I assume would be with the spring under tension, that is with the counterweight pushed all the way down?
Car is a 68 cutlass Supreme with a 350 and is not in a cold climate.
TIA
Mark
Old Mar 25, 2019 | 05:05 AM
Ozzie's Avatar
TIA
Mark
If it's not in a cold climate, it's probably not needed. I believe I just released the spring and it keeps itself open with the weight in the down position.
Old Mar 25, 2019 | 06:32 AM
I've wired the heat riser open or cut them out completely.
Old Mar 25, 2019 | 06:47 AM
x2
The valve on the exhaust manifold of my 64 98 was rusted 1/2 way shut so I removed it.
Old Mar 25, 2019 | 07:13 AM
mrolds69's Avatar
In the old days, they actually made a special hi-temp spray just for that. I've got a can of BP stuff in my garage can collection.
KQQLCAT
Dec 20, 2018 04:00 PM
FTolliver
Mar 28, 2014 08:12 AM
hurstoldsgal
Aug 19, 2011 10:32 AM
oldsracer
Sep 1, 2009 03:24 AM
RAMBOW
Aug 12, 2009 06:24 AM
