394 Left Side Dual Exhaust Manifold
Old Dec 18, 2018 | 05:48 AM
KQQLCAT's Avatar
I would like to find the heat riser for this manifold so the exhaust pipe fits better. Do any other makes work?
Old Dec 18, 2018 | 05:55 AM
Have you eliminated the heat riser from your exhaust manifold? Have you taken your Olds to an exhaust shop to see if they can fabricate a new exhaust crossover?
Old Dec 18, 2018 | 11:31 AM
D. Yaros's Avatar
Heat risers are able to be found. Look on ebay for starters, and Fusick.
Unless one does a whole lot of cold weather driving, it really is not needed. Better off to try and locate a heat riser eliminator or simply remove the internal butterfly valve in the current one.
Old Dec 20, 2018 | 07:30 AM
KQQLCAT's Avatar
What I have now is the left dual exhaust manifold from a 64 Starfire but don't have the heat riser that has the built in donut. If and when I find one I plan on gutting it and plugging holes.
Old Dec 20, 2018 | 01:51 PM
D. Yaros's Avatar
I presume by left you mean driver side? That is where the heat riser is located on my 1962.
It would seem that someone has made a replacement spacer for this application? At least they should have! I know that spacers are/were available for some mid-fifties Cadillacs.
Old Dec 20, 2018 | 04:00 PM
Oldskeeper's Avatar
Hi KQQLKAT,
I sent a PM about the heat riser.
Steve
willywonkadude
23
Nov 6, 2024 05:17 PM
59Rocket
Feb 12, 2016 09:02 PM
Bill Tupper
Apr 10, 2015 08:24 AM
Buckner
Ninety-Eight
Apr 26, 2013 11:06 PM
KQQLCAT
Oct 29, 2007 03:47 PM
