Choking on the costs to divorce
Old Dec 4, 2013 | 02:48 PM
RROLDSX's Avatar
I was on Epay and some guy wants $300 for a divorced choke for my 69 400
quadrajet. That's insane. So anyway I was hoping someone had one on here to sell me for about $10 bucks
Failing that, is there somewhere I can find highly detailed instructions on which electric choke conversion to buy and how exactly it is installed and adjusted. I will be using a 69 Rochester 4BBL on a 1973 smog 455?
Old Dec 4, 2013 | 02:58 PM
tru-blue 442's Avatar
Old School Olds
Hopefully, someone has one for you.
Riggi'n a 73 would suck, won't look right either.
I think the 68-69 4 bbls all Olds BB are the same.
Old Dec 17, 2013 | 02:48 PM
Montana67442's Avatar
I have seen chokes that look very close to Olds chokes in OPGI.com.
Old Dec 17, 2013 | 04:19 PM
Octania's Avatar
$300? What condition?
I have a spare used one
Chris
517..449.oh 43 two
Old Dec 17, 2013 | 04:22 PM
dc2x4drvr's Avatar
NAPA sells an electric choke conversion for your Q-Jet. Easy install.
jensenracing77's Avatar
Are there differant one for differant engines? I have two that i come across in my boxes of stuff. I am not sure what they are from but if there is a number on them maybe someone could look them up?
Old Dec 20, 2013 | 10:15 AM
RROLDSX's Avatar
According to the newly posted Master Parts catalog, generously provided by OLDSmobility (awesome dude!) the part number is 7036435 which describes it as Choke shaft and Lever kit. Not sure if that includes everything that is needed from the manifold up to the carb or not. According to the manual, this covers all 1969 4 BBL for every motor and transmission combination. According to Tru Blu 442 this would apply to a 68 as well.
Thanks dc2x4drvr, I'll check out the Napa conversion as well, in the meantime still looking for the divorced if very reasonalby priced. Thanks all!
Old Dec 20, 2013 | 10:53 AM
I just saw this thread.
The first question we should be asking is, Are you using the original 1973 intake manifold, or the 1969 intake manifold?
You cannot use a divorced choke on a 1973 manifold - there is no place in the casting for the spring.
Similarly, you cannot use a hot air choke on a 1969 divorced-choke carburetor.
If you're planning on mixing and matching, your only choice is a manual choke (unless you mix and match the other way, using a '73 carb. on a '69 manifold, in which case you can go manual or electric).
Old Dec 20, 2013 | 10:55 AM
Eric, Now I'm really confused
I thought you Had to use a 69 manifold
Old Dec 20, 2013 | 10:59 AM
As seen in my thread on the subject:
Note the difference in the castings for the hot air choke tubes (gold small block manifold) and divorced choke spring (red big block manifold).
Old Dec 20, 2013 | 11:10 AM
Sorry Eric, I miss read the OQ
Originally Posted by MDchanic
You cannot use a divorced choke on a 1969 manifold - there is no place in the casting for the spring.
I think you mean "you cannot use a divorced choke on a 1973 manifold..."
Old Dec 20, 2013 | 11:14 AM
Um. Yeah. Duh.
Old Dec 20, 2013 | 11:17 AM
I feel so much better now
Old Dec 20, 2013 | 11:39 AM
RROLDSX's Avatar
Yes the 69 manifold, although the 73 manifold is currently on the car I will be switching it out unless there is some benefit to keeping the 73 on. I now gather from what you are saying, I cannot keep the 69 carb on the 73 manifold even with an electric choke conversion. Do I understand that correctly? If I keep the 73 manifold on I should looking for a different carburator. Thanks for your expertise.
Old Dec 20, 2013 | 11:42 AM
Yeah, you've got it, unless you install a manual choke.
If you're installing the '69 manifold, then no problem, and it looks like some of the guys may have the parts you need, too.
Old Dec 20, 2013 | 12:43 PM
hookem horns's Avatar
Buy or make a choke bloke off plate for the manifold and get an electric choke conversion kit. Joe Padavano posted a nice way to wire it up or go simple like I did and tie into to wiper feed (someday I'll fix it up right).
Old Dec 20, 2013 | 03:01 PM
Those don't work with the '69 carb. he is using.
Old Dec 20, 2013 | 04:58 PM
Octania's Avatar
Right, as configured originally
Now, one *can* convert the 68-9 carb to Hot Air choke and then convert that to Electric or Manual choke...
I have done this, and converted hot air '69 carbs back to divorced choke. It's a bit painful, because the choke linkage all the way to the choke shaft differs, and on one type the link does not come off the shaft, so you have to swap entire shaft/link or the entire air horn assembly. Painful, but possible.
Where were we?
The OP needs either a divorced choke coil and the intake to match, or a later carb that can be hot air or manual or electric - right?
I have the numbers that you can actually read on the part in my database
busy right now, please stand by...
Old Dec 20, 2013 | 11:57 PM
RROLDSX's Avatar
Is this the correct one?
https://www.thepartsplaceinc.com/ima...os/CB1519T.jpg
It appears The Parts Place has just started to sell these chokes that are supposedly for a 68/69 4 BBL at what appears to be a more reasonable price.
Before I make the purchase can anyone verify this is the correct one? I can't verify from the schematics or part numbers I have.
Thanks,
Randy
Old Dec 21, 2013 | 05:46 AM
starfire's Avatar
Wouldn't it just really be easier and cheaper in the long run to get a 1973 carb?
Old Dec 21, 2013 | 06:42 AM
Old School Olds
Randy, Pretty sure that is the one.
The red one in the pic is from a 69 400.
The other is from a 66-67 to be used with
the shallow pocket manifold.
Old Dec 21, 2013 | 07:05 AM
I agree. The red one in the picture, and the one in the previous picture, both look like the correct '69-'70 unit.
Old Dec 21, 2013 | 07:21 AM
Octania's Avatar
Agreed
Taller unit with angled top part is 66-7
From the PN database [actual stamped-in number in bold type]
Group 3.750
The taller angled-top unit:
PN ???????
COIL Choke Coil Thermostat,
. Stamped RP (Rochester Products) "33762".
1967 V8 330 with C.C.C. (Climatic Combustion Control) all trans.
Quadrajet 4bbl Carburetor
1967 V8 400, 425 with C.C.C. (Climatic Combustion Control) all trans.
Quadrajet 4bbl Carburetor (exc. Toronado)"
The shorter flat-roof type
PN 7029094
COIL Choke Thermostat, 1968 Oldsmobile All Models with V-8 engine and 4 Barrel Carburetor Except Toronado
Stamped "35038"
PN 7036095
66-67 Toronado
Stamped "29984" - RP 29984 B-1
1966 V8 330 all transmissions (exc. Jetaway with A/C) 4bbl Carburetor
1966 V8 330 A/T Jetaway with A/C Rochester 4bbl Carburetor
1966 V8 400 A/T (exc. Jetaway with A/C) Quadrajet 4bbl Carburetor
1966 V8 400 all trans. (excludes F-85, A/C, & 4-4-2 with Jetaway) Quadrajet 4bbl Carburetor
1966 V8 425 A/T (exc. Jetaway with A/C) Quadrajet 4bbl Carburetor
1966 V8 425 A/T 4-4-2 with Jetaway and A/C Rochester Quadrajet 4bbl Carburetor
The above info is only as accurate as I can get from collecting off parts cars and looking up applications in the 1972 PN Manual. I had identical PN's for the first two, so that much at least needs to be corrected. The '094 PN comes from a recent epay ad 12/2013.
Old Dec 21, 2013 | 08:08 AM
Old School Olds
Just to clarify the post above,
The red unit is RP pn 35038.
And the 66-67 has RP pn 33762
Old Dec 21, 2013 | 10:03 AM
RROLDSX's Avatar
You guys really are amazing with this stuff! I really appreciate the help on this. I can now go forward with this purchase confidently. Starfire I appreciate the idea as I may still do that if I can score one for cheap as it will be a while before I replace the intake manifold.
I now understand what is required in both the 69 and 73 carb/choke system.
Thanks all,
Randy
Old Dec 21, 2013 | 06:32 PM
starfire's Avatar
Check Ebay, they have 73 carbs from $9.95 to $250.00.
I've been dealing with this forever now as I have a '68 carb on my '67 330. I've been running a manual choke. I've got the '68 intake ready to go, just need time to install it. Tried to put a '67 carb on it, but the one I bought online from a supposedly reputable speed shop in Lansing won't run (idle mixture screws are frozen). So I need to either fix the carb or change out the intake. I think it will be easier to fix the carb.
gearheads78
Aug 29, 2014 10:03 AM
navvet
Jun 18, 2012 08:42 PM
mhood
Sep 16, 2010 06:37 PM
import extermination
May 12, 2009 10:37 AM
68Tom
May 7, 2008 04:05 PM
