rebuild costs?
Old May 11, 2009 | 07:54 PM
import extermination's Avatar
rebuild costs?
aprox. how much is it to rebuild an 455 engine( lets just say it all needs to be done). i really just wanna know how much i should be putting aside for this project
the crank is 10/10, and the block was checked for cracks
totally new to this, thanks
jake
Old May 11, 2009 | 08:29 PM
2blu442's Avatar
Depending on what your machine shop charges, and what componets you purchase for the engine... and if you do the assembly yourself after the machine work is done I'd give you a range of $1500 to $2500. That's kind of broad but the shop rate, what your block needs, and the kind of parts you use can make a big difference. If you don't have a machine shop picked out you might post the question in a new thread. I believe there's several members here that live in B.C. or down in Seattle if your not too far North into B.C. John
Old May 11, 2009 | 08:34 PM
no i dont have a machine shop picked out yet, im kinda looking around,im located in chilliwack bc, 2 hours out of vancouver.
thanks
Old May 11, 2009 | 10:41 PM
hamm36's Avatar
John is right on. I spent 2500 putting 455 back to stock, parts and labor. That was block assembled and head work.
Old May 12, 2009 | 05:30 AM
442scotty's Avatar
I had mine done last fall here in calgary at one of the best shops..Precise...Cost me 4000. Nothing fancy...just wanted a high torque, bullet proof street engine that will last a long long time...blueprinted..and they assembled up to the intake. Things are a little more expensive North of the border and good shops are getting harder to find.
Old May 12, 2009 | 07:39 AM
citcapp's Avatar
Because of the dollar exchange rate I would put the cost at around 4K as well. It goes up from there depending on what your goals are for HP and torque. 6k to 8k is not unheard of
Old May 12, 2009 | 10:07 AM
Keep in mind that there is a difference in labor costs if you do the assembly or have the shop do the assembly.
Old May 12, 2009 | 10:37 AM
68Tom's Avatar
I just had my 400 rebuilt and it ran around $3200 w/ assembly.
projectheaven
Oct 9, 2012 03:33 PM
auto_editor
Jul 28, 2011 08:20 AM
Moses
Nov 21, 2010 04:31 PM
mhood
Sep 16, 2010 06:37 PM
68Tom
May 7, 2008 04:05 PM
