choke not working
choke not working
Does anyone have a diagram of the choke assembly on a 1973 rochchest 4 bbl carb..My choke is not working when i bought the car...I didnt know it until i got it home..The arm of the choke has a wire threw it tied down so it will not operate..I unhooked the wire and gave the car some gas and the arm kicked up and the plate closed on the front part of the carb..The problem is it never kicks off....
OLDS64
thanks man,,,I got it reset and it work now...Should the choke plate be straight up and down when the engine has warmed up...Mine is opening as it gets warmer but dosent go straight up and down...
Yep,,its working,,,,,So basically if you turn the black cap more it will take longer for the thermostat spring to open correct? How high should it idle when the choke is on...? And what should the idle be when the choke is off
You set your fast idle to determine the idle speed in park with the throttle plates on the lowest step of the fast idle cam. Set the slow idle with the choke disengaged to determine your idle speed in drive.
