72 442 Tachometer issue
Old August 6th, 2017, 03:43 PM
servexcell's Avatar
What should i check for all other gauges work except the tach.
Bruce
servexcell is offline
Old August 6th, 2017, 03:50 PM
Ground and tach signal from the coil- post.
https://classicoldsmobile.com/forums...ck-wiring.html
https://classicoldsmobile.com/forums...-question.html
oldcutlass is online now
Old August 7th, 2017, 08:24 AM
Bruce
You should check the wiring diagram in you Chassis Service Manual (FYI, the wiring diagram for the Rally Pac is in the Accessories section in Chapter 15). You'll find that the wiring for the tach is completely unrelated to the wiring for the other gauges. The tach has separate power, light, and tach sense wires. The ground is provided through the case to the ground straps in the dash.
joe_padavano is online now
Old August 7th, 2017, 08:37 PM
servexcell's Avatar
would you be able to send me the diagram
thanks
Old August 10th, 2017, 09:59 AM
servexcell's Avatar
Looking for wiring diagram 72 442 w30
thanks bruce
Old August 11th, 2017, 06:14 AM
oldspackrat's Avatar
Hey Bruce I just took some pictures out of the service manual and I can text them to you if you want? Text me 317-727-7041.
Scott
oldspackrat is offline
1yesfan
August 4th, 2015 06:40 PM
Dead Reckon
July 14th, 2014 02:35 PM
425HP409
October 27th, 2010 07:58 PM
67442HT
September 30th, 2010 01:39 PM
alexrains
December 9th, 2009 02:49 AM
Quick Reply: 72 442 Tachometer issue
