72 442 Tachometer issue
Old Aug 6, 2017 | 03:43 PM
servexcell's Avatar
What should i check for all other gauges work except the tach.
Bruce
Old Aug 6, 2017 | 03:50 PM
Ground and tach signal from the coil- post.
https://classicoldsmobile.com/forums...ck-wiring.html
https://classicoldsmobile.com/forums...-question.html
Old Aug 7, 2017 | 08:24 AM
Bruce
You should check the wiring diagram in you Chassis Service Manual (FYI, the wiring diagram for the Rally Pac is in the Accessories section in Chapter 15). You'll find that the wiring for the tach is completely unrelated to the wiring for the other gauges. The tach has separate power, light, and tach sense wires. The ground is provided through the case to the ground straps in the dash.
Old Aug 7, 2017 | 08:37 PM
servexcell's Avatar
would you be able to send me the diagram
thanks
Old Aug 10, 2017 | 09:59 AM
servexcell's Avatar
Looking for wiring diagram 72 442 w30
thanks bruce
Old Aug 11, 2017 | 06:14 AM
oldspackrat's Avatar
Hey Bruce I just took some pictures out of the service manual and I can text them to you if you want? Text me 317-727-7041.
Scott
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
425HP409
Oct 27, 2010 07:58 PM
67442HT
Sep 30, 2010 01:39 PM
alexrains
Dec 9, 2009 02:49 AM
