1966 Olds Cutlass Steering Shaft and Column
Old Feb 15, 2022 | 01:41 PM
JPWesten's Avatar
Question 1966 Olds Cutlass Steering Shaft and Column
I am restoring a 1966 oldsmobile cutlass. the rag joint tore on it so I am in the process of putting a new one on. I pulled the column and shaft then realized the shaft bearing the goes into the column is busted so I need to replace that as well. My question is does anyone know where I can purchase a new or used and intact bearing? Also wondering how and if I need to get the shaft out of the column to replace it?
Pictures of the bearing in question attatched:
Old Feb 15, 2022 | 03:01 PM
66luvr's Avatar
I bought one a couple years ago from NPD, but now they sell a brass bushing instead of a bearing.
BEARING, Steering Column, Lower, Item has been redesigned no longer a bearing but a machined brass piece, item fits tighter and will last longer than orginal design, Repro - #C-6521-100A - National Parts Depot (npdlink.com)
OPG has them;
Search Results for lower bearing steering column 1966 Chevelle @ OPGI.com
Old Feb 15, 2022 | 03:14 PM
JPWesten's Avatar
thank you for the links. I'll check them out. Do you know if I take the steering shaft out at the bottom of the column after removing the nut on the steering wheel?
Old Feb 15, 2022 | 03:27 PM
66luvr's Avatar
Yes, the shaft comes out the bottom, nothing but the wheel holds it in. There is an upper bearing, and there may be another nut under the wheel you would need to remove. My memory isn't that good, but it easily comes out, I have done it.
Old Feb 15, 2022 | 03:33 PM
JPWesten's Avatar
I appreciate the responses! I'll order that part from NPD and see how it goes. its super affordable so not really losing much if it don't work.
Old Feb 20, 2022 | 06:01 PM
JPWesten's Avatar
1966 Cutlass Steering wheel/column question
My steering shaft threads and nut were stripped when I removed the steering wheel. So I need to get a tap and die set to fix it.
Does anyone happen to know what size thread is on the nut and thread on the steering shaft that connects the steering wheel to the steering shaft?
Old Feb 20, 2022 | 06:28 PM
JPWesten's Avatar
1966 Olds Cutlass steering wheel and shaft
Old Feb 20, 2022 | 07:56 PM
Gary's 2 442-S's Avatar
Gary
I got the same problem on a steering column I bought from someone. I am going in the morning to NAPA or a hardware store and taking the shaft with me and if I am able to find the right size I will contact you. I have a tap and die set but my biggest die is not big enough.
Old Feb 20, 2022 | 08:26 PM
JPWesten's Avatar
I actually just found out mine was 1/2” - 13 thread.
Old Feb 20, 2022 | 09:01 PM
Gary
thanks
I will try to find a die in the the morning that size.
Old Feb 20, 2022 | 09:09 PM
edzolz's Avatar
Why have you asked the same question on two different forums? You will get the same answer, it won't change.
Old Feb 20, 2022 | 09:21 PM
JPWesten's Avatar
it was because my phone refreshed on the first one after I realized I put it in the one I did t mean to. Simple mistake no need to be rude.
Old Feb 20, 2022 | 09:22 PM
JPWesten's Avatar
thanks
no worries. Hopefully it works for you as well.
Old Feb 21, 2022 | 04:57 AM
Bfg's Avatar
Bfg
Ain’t you got no Lernon boy?
Old Feb 21, 2022 | 08:29 AM
Gary
My shaft has metric threads. What a big surprise to me. The die I needed is a 14mx1.5. Had to order one since none of the stores around here had one.
kencpless@gmail.com
May 17, 2021 01:26 PM
sortasane
Sep 8, 2020 08:17 AM
Sampson
Feb 3, 2014 05:41 PM
hurstman1972
Feb 22, 2012 07:45 PM
xx69442
Oct 14, 2010 04:39 PM
