64 column shaft conversion
Man its cool to see all the 64-65 cultass content recently.
As you may know the column on a 64 is a straight shaft. I have a spare gm collapsable shaft. I was thinking about using a round to DD straight coupler, and then changing the rag joint out with a universal joint with the correct spline to go to the steering box.
I'd like to hear your thoughts here. The coupler would be welded in and the univesal joint would be the style that uses set screws. Both are avaliable through Borgeson.
My concern was just safety. Having not grown up in an era where most people drive cars of this vintage I have to rely on anecdotal evidence
steering columns hitting you in the chest is something I’ve always heard would happen in a crash. While I don’t plan on getting into a wreck….. have you seen how everyone else drives
I'll be honest, I went through a similar thought process when I first put my 62 on the road. The reality is that given the limited number of miles that I drive the car and the conditions under which I drive it, the actual risk from the solid steering shaft is pretty small.
Yeah, part of my day job is risk assessment in spacecraft and launch vehicle projects.
