Stock Cam verses Efficiency Cam?
Old June 22nd, 2015, 10:05 AM
grmchne78's Avatar
If you were going to rebuild a small block Olds for daily use, what cam would you run? OE or something else?
87 Cutlass with 2:56 gears.... TH 350 trans...
grmchne78 is offline
Old June 22nd, 2015, 10:20 AM
It depends on what your trying to accomplish and the rest of the parts used in your rebuild. Are you rebuilding the engine back to stock or going for performance? Those gears won't work for a performance build.
oldcutlass is online now
Old June 22nd, 2015, 10:39 AM
grmchne78's Avatar
Stock. 8.0-1 compression daily driver - fuel economy, if there is such a thing... I already have a performance minded 455 car, this will likely be a freshened up 403 replacing a 307, so the 2:56's will likely stay, the 403 torque might help it in part throttle cruise situations.
Old June 22nd, 2015, 10:42 AM
Is this the car with the engine knock? If your on a budget to just get the car up and running then what ever is cheap.
Old June 22nd, 2015, 08:51 PM
grmchne78's Avatar
Yes, this is the 307 car with a knock. Would you consider ne lifters on the existing OE cam?
Old June 22nd, 2015, 09:13 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
You can go bigger, the stock cam is so mild. Even the lazy Performer cam will work with a stock 403.
olds 307 and 403 is offline
Old June 25th, 2015, 03:07 PM
grmchne78's Avatar
I've run the performer in a 350 and it was OK, is there a better alternative?
Old June 25th, 2015, 06:23 PM
Yeah, lots of them.
The Performer cam is 204º @ .050" lift and 280º advertised duration. Compare to a Crane Cam that has the same 204º @ .050 but its advertised duration is 260º.
http://crane.carshopinc.com/product_...d/16380/803902
Fun71 is online now
delta881972
May 14th, 2020 12:41 PM
fastolds
October 10th, 2016 05:32 AM
odddoylerules
24
January 22nd, 2014 06:35 AM
delta254
December 3rd, 2012 08:37 AM
Dan Wirth
September 1st, 2009 07:13 PM
Quick Reply: Stock Cam verses Efficiency Cam?
