Special-order 1970 4-4-2
Old August 1st, 2014, 01:31 PM
Diego's Avatar
http://www.ebay.com/itm/Oldsmobile-4...US_Cars_Trucks
Diego is offline
Old August 1st, 2014, 01:35 PM
morgan
pogo69's Avatar
great shape
pogo69 is offline
Old August 1st, 2014, 01:42 PM
Oldsmaniac's Avatar
Well I dont have a 70 paint chart handy but there was a raspberry/pinkish color for the Toro only in 1970 however the paint that is on this car does not look like it. It appears to be more chocolate color....
Oldsmaniac is offline
Old August 1st, 2014, 02:07 PM
BeenThere's Avatar
Luv the matching numbers 10 bolt rear end!!
BeenThere is online now
Old August 1st, 2014, 06:35 PM
hurst68olds's Avatar
paint code 76 was "Regency Rose Metallic" Toronado/Riviera "Sunset Sage Metallic" ONLY - the paint chip look to have more "pink" in it VS. the pics on eBay (could be the lighting??)
hurst68olds is offline
Old August 1st, 2014, 07:39 PM
oldsmobiledave's Avatar
Fyi
I asked him to prove that this was a 1 of 1 car....he chose not to reply.
oldsmobiledave is offline
Old August 1st, 2014, 07:43 PM
Diego's Avatar
He's supposed to post a pic of the data plate tomorrow.
Diego is offline
Old August 1st, 2014, 08:11 PM
Shoveling Snow
Hairy Olds's Avatar
Regardless of the 1 of 1 the color in my opinion does not work with the shape of the car, looks bland.
Color does not always dictate value.
Hairy Olds is offline
Old August 1st, 2014, 08:12 PM
Diego's Avatar
Of course color dictates value - how could it not?
Diego is offline
Old August 1st, 2014, 08:22 PM
brddg's Avatar
Of course color dictates value. Desireable colors bring more and undesirable colors bring less. How is it determined that this is a one of one car? Also, I thought special order colors were represented with a dash at the color code line of the cowl tag. Am I mistaken about this?
brddg is offline
Old August 1st, 2014, 08:24 PM
Diego's Avatar
When it comes to Olds data plates, I think they did things differently than other brands in GM. Just like the extra-cost colors often had dashes, I know I have seen a special-order car or two with the proper paint code. Prob if it had a non-RPO color outside 1970 GM, it would have gotten the dashes for sure.
Diego is offline
Old August 1st, 2014, 09:04 PM
If the cowl tag shows two dashes for the PNT code, the only way this car can be proven to have that color would be to also have the build sheet. Since it's a Freemont car, it might be on there. I have also seen cars with extra cost paint with the color palet code listed correctly. This will be interesting to see how it plays out.
I also would like to know how to prove 'one of one'. No records exist that I'm aware of that document the number of special order cars produced by Oldsmobile.
Whoever did the respray did a nice job, but sad to see the manufacturing decal and tire pressure decal on the drivers door are missing. Also, where's the washer fluid reservoir gone, and where is the wheel opening trim? Those were standard on 1970 442's IIRC.
Allan R is offline
Old August 1st, 2014, 09:36 PM
Diego's Avatar
To me, when someone says "1 of 1" it's just another way of saying "This one is special - I date you to find another one."
Which is BS either way.
Diego is offline
Old August 1st, 2014, 09:42 PM
Shoveling Snow
Hairy Olds's Avatar
You missed the little word "always".
Old August 1st, 2014, 11:09 PM
Diego's Avatar
Color "always" dictates value. Goose-$#!+ green is always going to be worth less than Rally Red, all things being equal.
Diego is offline
Old August 1st, 2014, 11:50 PM
johnnyjaws's Avatar
I find it funny that someone and I know it happens to not put out the extra $ what 60.00 bucks and not get the 442 cowl hood on it
johnnyjaws is offline
Old August 2nd, 2014, 06:54 AM
special option color only for tornados
I wonder what the special option color would be for sharknados?
joe_padavano is online now
Old August 2nd, 2014, 06:56 AM
The bigger problem is that once again, here's a high dollar, fully loaded car with alleged rare paint, that has been subjected to a complete restoration and repaint! How many of these options were added when the car was apart? Is this color even the original color of the car? Inquiring minds want to know.
Old August 3rd, 2014, 08:41 AM
stevengerard's Avatar
data plate says 76-76
nice looking car - bet it looks better in person in the sunlight.
stevengerard is offline
Old August 3rd, 2014, 11:11 AM
Good catch Steven. For some reason not all the images on the ebay listing would load when I looked at the ad the first time. The color palette and data plate were 2 of them. I think that establishes this cars paint fairly well. Obviously it had to be special ordered to get that.
It looks like this car was built in Freemont. Also a very low body number that would tend to support that so the build sheet may be still with it somewhere? The seller makes no mention of other documents (POP, build sheet, broadcast cards, original BOS etc) that would add to this cars provenance. I noted the fuel tank is painted black, which leads me to question whether this was a body on or body off restoration. The build sheet could still be on top of the tank....just thinking out loud here.
Allan R is offline
Old August 3rd, 2014, 11:37 AM
pay
Of course you realize that this was three days take home pay at the time.
Old August 3rd, 2014, 11:58 AM
Diego's Avatar
For the life of me I couldn't figure out what the "cowl hood" was till now.
The W-25 wasn't everywhere back when new, showing up in 12.8% of production through June 1970. That doesn't include 3100 W-30s built, so total production would likely be under 6,000 4-4-2s for 1970.
Diego is offline
Old August 3rd, 2014, 12:26 PM
Help the ignorant here, but the Oldsmobile script on the left tip of the hood is correct on which cars in 1970?
Koda is offline
Old August 3rd, 2014, 12:31 PM
I'm 99% sure that's correct on a 442 without the OAI hood for 70. The real issue is when is the last time you have seen a 1970 442 with out the OAI hood
Old August 3rd, 2014, 02:21 PM
oldspackrat's Avatar
'71 turn signal lever, 10 bolt rear end, incorrect oil filler cap, funky brake booster, '72 AC hose with muffler. Not to be a nit picking jerk, but the description does say museum quality.
Koda & Steven,
The Oldsmobile emblem on the left front of the hood is correct for the '70-'72 442s without OAI. Also maybe the '69s?
oldspackrat is offline
Old August 3rd, 2014, 04:17 PM
69 hood emblem
Koda & Steven,
Not correct for 1969 442 but correct for 1969 Cutlass.
Old August 3rd, 2014, 04:27 PM
Koda & Steven,
That oil filter cap is correct I'm pretty sure. - wrong alternator, wrong floor matts
Old August 3rd, 2014, 05:17 PM
Steven,
You're right, at first quick glance I thought it was the type with the vertical fin along the top, thanks for the correction.
Old August 4th, 2014, 05:59 AM
Oldsdruid
rocketraider's Avatar
Looks like Regency Rose to me, or really looks more like 1971 Briar. The colors were similar but different codes.
That pinkish rose was called Flamingo Silver. Again, Toronado-only.
Odd color for a 442 but I like it. I get tired of seeing them in the same old resale colors.
rocketraider is offline
Old August 4th, 2014, 06:36 AM
vs Briar
I owned a 1971 Briar car. It is more brown.
Old August 4th, 2014, 10:21 AM
  #31
Well, my color blind a#@ can't tell what it is, just a drab color to me.
1969w3155 is offline
Old August 4th, 2014, 05:18 PM
  #32
So you're color blind Dan? It's bright orange... with a hint of lime and yellow....Doesn't look drab at all.
Allan R is offline
Old August 4th, 2014, 05:23 PM
  #33
Not that color blind!
LI Olds
December 24th, 2012 04:06 PM
GAOldsman
December 20th, 2012 07:14 AM
jensenracing77
Paint
July 22nd, 2012 09:46 AM
BigMike70
January 10th, 2010 11:29 AM
klilly80
July 6th, 2008 12:11 AM
Quick Reply: Special-order 1970 4-4-2
