Air compressor water trap question
Old October 22nd, 2013, 10:58 AM
rktolds's Avatar
I'm setting up my shop and want to see what other have done with black pipe. How have you kept water out of your system? I have a blast cabinet and will paint parts too. If you have pics that'd be great. I am a visual person. Thanks for the help.
rktolds is offline
Old October 22nd, 2013, 11:06 AM
Just install an air dryer at least 15' from the compressor to remove moisture.
Allan R is offline
Old October 22nd, 2013, 11:12 AM
I used a down pipe to trap the water with an automatic drain and a tube to exit outside. I also used and automatic drain at the bottom of the tank.
oldcutlass is offline
Old October 22nd, 2013, 11:45 AM
BackInTheGame's Avatar
Shop Air
I'm going to be going down this path in the next few months myself.
Oldcutlass, I've not heard of an automatic drain for the water. What/How/etc., if you don't mind sharing.
BackInTheGame is offline
Old October 22nd, 2013, 01:48 PM
Something like this:
http://www.grainger.com/Grainger/CON...302?Pid=search
http://www.grainger.com/Grainger/WIL...T04?Pid=search
Old October 23rd, 2013, 09:55 AM
Automatic Drains
Those are cool, I never even suspected such things existed! Thanks for sharing.
Rich
Old October 23rd, 2013, 12:37 PM
Automatic drains are cool but not necessary. A manual ball valve works fine (assuming you remember to drain it regularly, of course). Here are two diagrams from TP Tools that are a good tutorial on compressed air piping design.
joe_padavano is offline
Old October 23rd, 2013, 12:48 PM
car guy
gearheads78's Avatar
What tells those when to open? I have only seen electric ones on a timer.
gearheads78 is offline
Old October 23rd, 2013, 05:42 PM
Sampson's Avatar
I sell industrial A/C and also design air systems. Joe and Eric are both correct. Just two different approaches to the same problem. Jos's approach is the most simple method. Water being heavier than air settles to the lowest point in the system. Open the manual drain valve daily and let the water flow until air comes out and you are good. Just make sure you remember to open the drain daily. Eric's method takes the guesswork out and drains the system automatically. There are 2 types of auto drains: timed drain, which opens by a preset timer, and float drain, which opens when the moisture level lifts a float valve off the seat. When designing a system always have the drop from the header come from the top of the pipe. A drop would be a hose or pipe that hooks to the tool. A bit of trivia about moisture from compressors. A 25 hp compressor running continuously will produce up to 18 gal. of water a day!
Sampson is offline
Old October 23rd, 2013, 06:56 PM
I personally like the electric chillers that condense the water out.
Don't have one, but I like 'em.
MDchanic is offline
Old October 23rd, 2013, 07:10 PM
rktolds's Avatar
Thanks guys. That TP set up gives me some ideas. I have a water separator and pressure reg/filter set up. Now I can picture how to set them up.
rktolds is offline
Old October 24th, 2013, 05:50 AM
There's a 100 + ways to set up a pneumatic plumbing system and almost as many to get moisture out. The price can range from cheap to a whole lot of $$$$$. I'm a big fan of coalescing filters and drains, there is nothing worse than getting your air tools and paint guns all sludged up with dirt and grime.
notchback
October 7th, 2013 10:19 PM
at3reg98
June 8th, 2012 07:02 PM
Hairy Olds
July 12th, 2009 09:21 AM
1FSTLS1
December 28th, 2007 07:45 PM
jaco
January 5th, 2007 08:57 PM
Quick Reply: Air compressor water trap question
