70 to 71 Vista Front Clip Conversion
Old Jun 8, 2012 | 07:46 AM
66 Olznut's Avatar
Ca's Only Official OLZNUT
Question 70 to 71 Vista Front Clip Conversion
I'm in talks to pick up a '70 Vista Cruiser for a song right now and I have a question. How easy is it to convert the front end to a '71 set-up? I like the grill better and would like to try to convert it if it's a simple bolt on process. Do the re-pop ram air hoods have good fit and durability? I have a '66 442 but this car would be a whole new adventure for me. I've always wanted a Vista Cruiser, really wanted a '66 but for the price this '70 is, I can't pass it up.
Old Jun 8, 2012 | 08:02 AM
66400's Avatar
The fenders and inner fenders are the same, you'll have to change every thing else, all a bolt on affair.
Hood, bumper, bumper brackets, grill, radiator core support.
Henry
Old Jun 8, 2012 | 09:33 PM
Rickman48's Avatar
Doghouse for doghouse - easy!
If I remember right, less than a dozen bolts, and leave the hood on for support.
Old Jun 10, 2012 | 02:44 PM
So far as the guys are reporting back, the ones from VFN and Fibreconcepts are top notch. Ultimately the best is the Thornton hood, but its huge $$$. The VFN is around 600 and the FC is 799 IIRC. If you're changing the rad support, you can use a donor from either a 71 or 72.
And Rickman is right, you can swap out rad supports with the hood and fenders still on.
Some other things you will need to change are the front bumper/mounting braces/park lights/stone shield/headlamp filler plates, and headlamp bezels. A fair bit of work, but not insurmountable.
Old Apr 21, 2017 | 11:55 AM
Adam34's Avatar
Im fixing to buy a 71 and was wondering if its possible to do a 69 front clip conversion. is this possible an if so how much welding would be required.
Old Apr 21, 2017 | 01:46 PM
tcolt's Avatar
Is it the one in Long Beach that you're buying? I looked at it a few weeks ago.
MarineJusten
Jul 6, 2014 10:02 AM
azcutlass68
Nov 26, 2011 06:49 PM
chino chao
Nov 22, 2008 04:54 PM
chino chao
Nov 21, 2008 06:10 PM
