66 Cutlass Trunk Lock - Need Help.
Old May 3, 2012 | 05:37 AM
guy.graziano's Avatar
Guys -
I am in the process of reassembling my 66 Cutlass, now that shes back from paint. I replaced the trunk lock, and retained it with the retainer without issue.
My question is - there is something missing on the underside of my trunk lid. The retainer sticks thru the slot, but there are 2 screw holes on either side of the slot and I assume there should be some kind of metal plate or gasket there...something. I bagged adn tagged all the stuff and I dont have whatever is supposed to be there.
HELP!
GG
Old May 3, 2012 | 07:44 AM
66luvr's Avatar
Here's what it looks like. It has a little gasket under it. These are likely NOT the correct screws, I seem to remember putting new ones there. Not much on the blue car is original so new was fine.
Old May 3, 2012 | 08:38 AM
Thats Awesome! Thank you.
Where did you get it ? Anyone repoping them ?
GUY
Old May 3, 2012 | 05:11 PM
66luvr's Avatar
GUY
Not sure I follow your question.
I said the SCREWS were new.
The black metal piece is the original piece that GM put on at the factory. I painted it black and I do not know if that is the correct color.
Sorry, I have no idea if it is reproduced, I didn't need one.
Good luck.
Old May 4, 2012 | 05:29 AM
Fusick has a rubber piece that is for 68 - 77 but it looks like it'll work.
I ordered it. WTF - I'll give it a try!
Old May 10, 2014 | 06:29 AM
jeffsims's Avatar
1967 442
Guys -
HELP!
GG
Was your retainer not part of the plate that screws to the bottom of the deck lid? I am reassembling my 67 that was torn down by my dad in the mid 80's. Yes, the mid 80's. Anyway, I found the plate with 2 screws in a bag, but no retainer. To me it looks like the retainer was torn off of this plate. Since I have nothing to compare to I am hoping someone in this forum can provide me with some insight on what the heck I am supposed to be looking for.
Old May 10, 2014 | 06:55 AM
RandyS's Avatar
The bracket looks like this one, except the base of it for the 66 is a bit different.
Old May 10, 2014 | 06:59 AM
Octania's Avatar
Yes, what RandyS shows IS the retainer. It slides in place over the lock cylinder, then the two screws secure it in place to the decklid, with a gasket there.
Old May 10, 2014 | 07:01 AM
66400's Avatar
I think you may be dealing with a retainer that has the end section broken off.
Henry
Old May 10, 2014 | 08:01 AM
Run to Rund's Avatar
Cover plate and retainer are red oxide, retained by two button head Phillips screws.
Old May 10, 2014 | 08:06 AM
jeffsims's Avatar
1967 442
Cover plate AND retainer? Are these 2 separate parts as Guy's original post sounds? Everything I run across on the net look like one pc as the most recent replies state.
The cover plate that I have is definitely red in color. I assume e red oxide.
-Jeff
Old May 10, 2014 | 09:43 AM
66luvr's Avatar
-Jeff
Well, I just went out to the white 67 and took the 2 screws out to see if this was two pieces. Best I can figure it is one piece. I pried it down a half inch and it was moving all the way up to the lock, so I think it is one piece. And it looks exactly like the picture I posted of the blue 66 car.
Now I do not remember if the 66 was one piece and I didn't try it today. But the 67 is one piece.
Old May 10, 2014 | 10:10 AM
RandyS's Avatar
The 66 is one piece also.
goldie442
Aug 21, 2015 11:01 AM
Chris289
Body work
Jan 5, 2015 10:27 PM
benjamin247
Oct 1, 2014 07:23 PM
Maverick
Apr 22, 2014 05:04 AM
randomarrival
Dec 22, 2012 12:28 PM
