Dieseling why?
Old May 9, 2014 | 10:34 PM
Tedd Thompson's Avatar
Dieseling why?
This just started today, keeps running after I shut it off. It may stutter and buck for 4 or 5 seconds after shut off. Why would it start now and should I worry about it or take care of it when I get home ? About 1500-2000 miles more before home... Thanks ...Tedd
Old May 10, 2014 | 01:07 AM
rustyroger's Avatar
'87 Delta 88 Royale
Try slowing down the idle speed a little Ted.
Roger.
Old May 10, 2014 | 01:17 AM
Yellowstatue's Avatar
And the idle speed might be affected by your present altitude or fuel quality. Seeing as how you are on the Mother Of All Road Trips... d.
Last edited by Yellowstatue; May 10, 2014 at 01:18 AM. Reason: Roger left off a d. for Tedd
Old May 10, 2014 | 03:04 AM
I think elevation is a good thought. Have you changed elevation much since you left? If so, then the idle may need to be adjusted, or the carburetor jets may need to be changed for optimal performance.
How hot has your engine been? Excess heat can help cause run-on.
It's unlikely you developed new carbon in your cylinders (another possible cause of run-on) after a road trip, as that's supposed to burn it off.
Old May 10, 2014 | 03:25 AM
jensenracing77's Avatar
Till you get to the root of the problem, You can turn it off while in gear and many times this will keep it from dieseling. This is not much of a solution but at least it don't look so bad when in a parking lot.
Old May 10, 2014 | 04:46 AM
tru-blue 442's Avatar
Old School Olds
I'm thinking you came across
some bad gas. Filler up
with some good 93 octane
and drive on.
Old May 10, 2014 | 05:26 AM
x2 on bad gas or altitude and turning it off in gear. Throw some fuel system cleaner of your choice in tank. Make sure your idle is not too high and the carb bottom butterflies are closing properly at idle.
Old May 10, 2014 | 06:40 AM
Thanks guys. I'm on my second tank of gas with the same results but we have been up and down in elevation like a yoyo. I will get the hi test next fillup. Getting between 12 to 15 MPG depending on whos driving...Tedd
Old May 10, 2014 | 06:48 AM
If she drives like my wife, 2 speeds, stop and go, go, gooooooooooooo.
Old May 10, 2014 | 11:12 AM
RROLDSX's Avatar
If your running lean at altitude, the carbon on your heads may get hot enough to fire the gas left sucking even more fuel through the carb while dieseling. I agree with turning it off in gear but I would check the plugs to see if it is running too hot. Just my 2cents.
Good luck Ted.
Old May 10, 2014 | 12:01 PM
Tedd, when's the last time you replaced your fuel filter? I've run into 'run on' conditions with a partially blocked filter.
CLcutlass
Jun 8, 2014 04:12 PM
EmilyAndTheJet
28
Apr 30, 2012 07:03 PM
Dan K
Dec 13, 2011 11:03 AM
Twilight Fenrir
May 26, 2011 06:42 AM
mkg230
Jan 15, 2010 07:52 PM
