Another oil filter question
Without having them side-by-side to compare, is there a benefit to running a PF24 over the PF30 that the manual calls for on my stock 455? (larger capacity, etc.?)
The PF-24 is a slightly smaller filter and superseded the PF-30 sometime in the late 70s. PF-30 is going to be a new old stock if you can find one, and I'm honestly wary of paper filter elements that are possibly decades old. There are era-correct white AC repro filters available but expensive and I don't know much about their internals.
The oil filter is an area where I simply go by "keep your GM car all GM" and use whatever application the current ACD catalog calls for on the old cars, even though the older numbers are usually superseded or consolidated with newer ones. I generally use a Purolator or WIX on the drivers.
Though I'm convinced Purolator and WIX are better filters than current ACD offerings.
If the part number does not have an "E" after the end, it is one of the quality filters made several years ago and I would get them. So far I have not seen any PF24E's around here but watch out...
WOW! NO Kidding?! i've not heard nor seen this 'E' designation after the PF24 or other number; BUT I'll certainly WATCH for it now!! THANKS for alerting us!
I guess maybe Wix/Puralator are better??? How about Fram?? Are those OK in the 'deluxe/Tuff" lines they have now everywhere???
Interesting thread!
Interesting thread!
![Cool](https://classicoldsmobile.com/forums/images/smilies/cool.gif)
The "current" AC Delco filters to avoid all have an "E" after the part number (stands for economy core by Encore".
Fram is on the avoid list, also.
Wix, Purolator, Motorcraft and the old AC Delco filters are very similar in quality and are recommended. 2-3 years ago, AC Delco changed their MFG process to Champion labs who makes this cheesy "E-core" design. It can be ID'ed by the "E" after the part number and 8 small holes on the filter. The good kind had 6 holes.
There is an extensive independent study on oil filter construction online somewhere that proved the internals of most major brands.
OK; fair enough! WORKS For me!! Yes, I recall that study now; I'll avoid FRAM now then. Purolators just for some reason always "LOOKED CHEAP" to me..."????
GOOD advice though and thanks again Rob for the Tips! ![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Oh here is the study:
http://minimopar.knizefamily.net/oilfilters/index.html
Thats a great study. I recommend reading it thoroughly. Since I've read the study I've been cutting open filters myself and studying them. Just to make it quick I will never ever use a A/C Delco or Fram filter again. Pure unquaility garbage compared to Purolator or wix. Quality filters I have cut open and disected are Purolator, Wix, Motorcraft, Mopar, Bosch, K&N, Mobil 1. I believe Purolator actually makes K&N and Mobil 1 filters..They are identical inside..save yourself the money and buy Purolator Pure 1.
Just keep in mind that many of the good, older ACD filters are still on the shelves and are easily identified.
https://classicoldsmobile.com/forums...tml#post249927
That study did not mention that.
Only the new ones with the E at the end of the part# should be avoided.
I hadn't been aware of that, and will no longer buy Fram filters as a result.
As for reverse snobbery, I'm quite content to be the sort of snob who goes forward in high gear.
No argument here.
A street motor is a street motor, and if I change my oil every 5,000 miles, I couldn't care less whether a given filter clogs up with junk and opens its bypass valve at 20,000 miles or 30,000 miles.
I'll take a look at those HP filters next time I'm in the auto parts store, though.
ps: your avatar makes me think I'm talking to my grandfather.
It's a bit weird, as he hasn't been with us for about 20 years.
My info that I have is now several years old, but came from an evaluation of the filters by cutting them open and examining the construction and materials used, and whether or not there was contamination of unfiltered oil getting back into the engine.
There is mention in that study of only one fram filter that was 'better' constructed and it is the tough guard, but had a higher cost to go with it. Also with the confusion of similar names (see all the crappo varieties in the 'avoid' list), and the cardboard cap in the TG, I would just forget about all of them.
Wal-mart has nothing to do with Fram - not sure how that came in to the story... They sell Motorcraft filters, too, and I buy those for my Ford - yes, from Wally! MC is still a good filter (for now I guess). I get the Motorcraft diesel oil from them, too, as it is fair priced AND comes in a 5 qt jug and not a stupid 4qt.
Fram also is on the shelves at many auto parts stores, they are the same ones on the Wally shelves.
I never heard of or saw the Fram HP filters, but they sound overpriced for a street engine. Other quality fair-priced filters are easily and more readily available.
The last AC delco filter I cut open didnt even have a bypass! I cut open a Fram filter to see Cardboard end caps. The Overpriced extraguard fram I opened was better than the regular but the elemant looked very restrictive. Why save 3 bucks and put these filters on your car whether its a $900.00 160,000 mile get around car or a $30,000 and up performance car? Its the oil that lubricates your engine and the filter that keeps that oil clean. Isnt that important? So is using a $6.00 Puralator pure 1 filter "out of my scope of design" even though Im putting it in my 1999 Dodge Avenger winter beater???? I guess I'm obsessed a little and just want whats best for my engines and have piece of mind that my filter wont fail from poor quality garbage.
On my two Grand Marquis the filters are horizontal, If I don't use a Motorcraft or a Napa filter it makes noises on start up. the cheap filters don't have adequate anti drain back diaphrams. I use Napa on my Cutlass.
oldspackrat
March 21st, 2016 05:17 PM
joepenoso
July 19th, 2013 12:44 PM
