Pypes down pies uncorked
Old Feb 16, 2026 | 07:19 PM
herkguy's Avatar
Pypes down pipes uncorked
Uncorking the Pypes…
I have the Pypes downpipes which have a 2” neck that attaches to 2.5” pipe for the rest of the exhaust.
it was fine with the stock manifolds, but I put the Thornton headers on which actually have a 2.5” outlet.
the Pypes were now a cork going 2.5” into 2” then back to 2.5”.
Brought them to my local exhaust specialist and had him remove the corks and add a new full 2.5” connector and also added O2 bungs for future tuning of the carb.
I have a second set of these that I will swap ends on also, if I get them done in time I will send them to Jerry so maybe he could dyno test his original Pypes against a full 2.5” with the manifolds and shorty headers. I gotta believe squeezing down to 2” killed some power.
Old Feb 17, 2026 | 04:35 AM
Nice that you have a local exhaust specialist now-a-days! Looks great!
Old Feb 17, 2026 | 04:42 AM
Going 2.5" to 2" to 2.5" may hurt HP numbers, but it will be undetectable with a butt-dyno.
Old Feb 17, 2026 | 06:36 AM
herkguy's Avatar
haha..totally. It has run fantastic as is, I am about to tune the carb and with the ported heads wanted to make sure the flow is all open before the carb tune. I bought a PE wideband O2 so I’m exited to try it out.
Old Feb 17, 2026 | 02:20 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
That looks great. Ram Air Restorations used to have a really nice 2.5" down pipes, unfortunately don't make them anymore. It would be nice if Thornton offered down pipes in 2.5" to go with their headers and larger outlet manifolds. Either way, fixed.
Old Feb 18, 2026 | 08:41 AM
P516's Avatar
I ran into the same issues years ago with Thornton shorty headers and Pypes down pipes. I got frustrated with Pypes poor response to my questions and put everything in the boxes and stayed with my long tube headers.
I must say, the Thornton shorties are good looking pieces.
Old Feb 18, 2026 | 09:28 AM
acavagnaro's Avatar
I ran this combination on my 400G for about 5 years. The Thornton description of the short tube big block headers states a 3" collector but the flange and ball shaped pipe mating face is designed for a 2.25 or 2.50" downpipe. This is due to the fact that the original factory exhaust was not 2.50". I never saw that neck on the Pypes downpipes as a performance harming restriction. Glad you're happy with your mods.
Old Feb 23, 2026 | 07:19 PM
herkguy's Avatar
New pipes on and match well to the header exits in size now.
also have the O2 bung installs on both for my new PE wideband O2 kit..can’t wait to get at that project
I need to clean up the bung welds in the future
69442murph
Aug 30, 2024 01:27 PM
Kreisk
Jun 5, 2022 07:20 PM
Stefano
Jan 15, 2021 12:29 PM
Btodd34
Apr 22, 2020 10:46 AM
freloncharlo
Sep 13, 2019 12:41 PM
