Aluminum Intake with OAI
Old Jan 8, 2022 | 06:34 PM
GN1220's Avatar
As purchased my car has an Edelbrock Performer with a 750 street demon installed. The OAI was modified to (kind of) work with this set up but I hate it. I do have a stock cast iron intake with a brand new Quadrajet that also came with the car. While I want to go back to a more correct Quadrajet I do like the look of an aluminum intake but can't afford a stock W-30 intake. What are you guys with aluminum intakes using to keep the carb lower for the OAI to look and function correctly? I would be more than willing to trade this intake and carb for just an intake if someone were interested.
Old Jan 8, 2022 | 06:46 PM
scrappie's Avatar
Edelbrock 04B performer Is the only one I know of with correct height.
Old Jan 8, 2022 | 06:51 PM
GN1220's Avatar
Thank you Scrappie, I'll do some research. Hopefully that isn't some rare intake made of unobtanium like a lot of stuff I'm discovering these days.
Old Jan 8, 2022 | 07:38 PM
VC455's Avatar
Barely Registered
The only option I know of to fit your Performer to the OAI hood requires ditching the Olds adapter. You would buy a 1970 Chevelle Cowl-Induction adapter, put it on your existing air cleaner base, and use a W31 foam ring instead of the Chevelle foam.
You would have cold air 100% of the time--the function but not the exact look. And the cost to do this is <$100, so you could consider it a good temporary fix until you get a lower intake.
p.s. There are reproduction W30 intakes out there for less money.
Old Jan 9, 2022 | 07:38 AM
HOT/ATOM's Avatar
https://classicoldsmobile.com/forums/big-blocks-2/clearance-oai-air-cleaner-hood-1101
This worked for me , inspite of what some - ok one resident expert might say . One other car ( 70 442 ) local has the same set up . Looks pretty doggone stock under the hood which was my goal . No Chinese intake for me & has hei distributor .
Old Jan 9, 2022 | 08:43 AM
GN1220's Avatar
I don't see any pic of what worked for you.
Old Jan 9, 2022 | 09:05 AM
Try this link instead of the one in his post title:
https://classicoldsmobile.com/forums...r-hood-110141/
And this one has pics of VC455's modifications:
https://classicoldsmobile.com/forums...arance-144272/
Old Jan 9, 2022 | 09:47 AM
HOT/ATOM's Avatar
Thanks Fun 71, I'm on the site a good bit but don't post much ! .
Old Jan 9, 2022 | 09:59 AM
My442's Avatar
That is what I have with a factory OAI set up.
There are 2 versions of the O4B: Q jet and Holley.
They are not that hard to find.
HEI will NOT fit.
Old Jan 9, 2022 | 10:02 AM
GN1220's Avatar
Thanks for all of the information guys. One thing I'm still not clear about; can an HEI be used with the 04B intake? At this point I think I'll have the stock intake cleaned and install it with the new Quadrajet. I just want original as I'm not into dealing with hot rod stuff anymore. Might even just detail the car and move it along.
Old Jan 9, 2022 | 10:09 AM
My442's Avatar
See last line in post #9
Old Jan 9, 2022 | 10:28 AM
GN1220's Avatar
Apparently I responded before that popped up. Thanks again guys, all of your information is greatly appreciated.
Old Jan 9, 2022 | 10:34 AM
Got pictures of your car etc?
Old Jan 9, 2022 | 10:56 AM
GN1220's Avatar
Factory U code with Saddle buckets, dual gate and rally pak, posi and added OAI hood before I got it. Super solid and rust free car, other than the panel behind the window, which I do have and will be installed in the coming months.
Old Jan 14, 2022 | 12:15 PM
tangokilo's Avatar
No. A GM style HEI with the large cap will not work with a 04B. A pertronix style conversion to the standard distributor would be fine. Or just run points like I do.
Post70
Jun 7, 2021 07:36 AM
Gary M
Oct 12, 2017 05:16 PM
Don Roberto
Sep 30, 2014 03:01 PM
jcl
May 15, 2014 02:17 PM
southcarolina803
Jul 2, 2008 07:14 AM
