OAI intake manifold
Old May 14, 2014 | 12:00 PM
jcl's Avatar
jcl
OAI intake manifold
Anyone know what after market intake works with a 1970 442 w30 OAI and still lines up and seals with the scoop opening in the hood?
Old May 14, 2014 | 04:00 PM
Funkwagon455's Avatar
The only aftermarket intake I'd know of would be the W-455 aluminum intakes offered by Parts Place.. They are the same deck as the factory issue, and would be a bolt in scenario. Other aluminum aftermarket intakes will require modification to the air cleaner or an aftermarket air cleaner that will drop the body enough to get clearance. I dropped my air cleaner body to make it happen with a Performer intake. It took a significant amount of metal work and careful measuring, but it looks right/sanitary and fits nicely. Maybe someone offers an out of the box version these days, I'm sure someone can shed some light on it.
Old May 14, 2014 | 04:40 PM
brddg's Avatar
Would you share some pics Funkwagon?
Old May 14, 2014 | 06:10 PM
Magna86's Avatar
You can also take a regular performer intake and have the carb base milled down about a 1/2" to get the proper clearance using the stock aircleaner.
Old May 14, 2014 | 06:15 PM
Gary M's Avatar
I used the parts place intake and it works great. The foam seal matches up with the screen on the hood perfectly and the intake seals just fine. Mine is 1972 just for your info.
dc2x4drvr's Avatar
Won't an Edelbrock 04B work without mods?
Old May 14, 2014 | 06:21 PM
Gary M's Avatar
The foam seal is thick and May squeeze down some to compensate for the Edelbrock.
Old May 14, 2014 | 06:28 PM
Sure, please excuse the condition of my engine bay. The bodywork prep and blocking is not clean work. I will post some photos from underneath on the weekend, I'll be loading it up to go to the painter and am keeping the breather here at the house. I will also take pictures of a standard air cleaner body and try to give the drop dimensions. I used an aftermarket air cleaner base cut out, and created additional drop with raw sheet metal bent into a Z joggle and used a sheet metal shrinker/expander to make it fit the round contour of the base. I also welded the original rolled carb flange to the base to replicate the original base to make it more professional, and seal nicely. I also had to use a couple of the exhaust riser tubes spliced and blended to make it fit correctly. It is not going to fool any of the master judges nor many of the experts here, but it does fit/function nice and looks better than some of the alternatives.
Old May 14, 2014 | 06:29 PM
Sorry, I am having trouble loading more than one image with my Ipad.
Old May 14, 2014 | 06:35 PM
Uno mas...
Old May 14, 2014 | 06:37 PM
And again,......
Old May 14, 2014 | 06:38 PM
I promise I am not going for posting volume here!
Old May 15, 2014 | 04:03 AM
My442's Avatar
Yes. That is what I use on my 70 442 with OAI.
The only thing you need to do is extend the heat riser pipe with a piece of exhaust tubing.
Old May 15, 2014 | 10:17 AM
jcl's Avatar
jcl
Thanks to all for the info.
Liking the performer option if all is good except the highth. With a good press and a little ingenuity, I think I could turn the base over and press the carb flange in 1/2" which should lower the rest. Worth checking out.
Had considered an 04B but I don't think there is clearance for a standard HEI distributor
Old May 15, 2014 | 02:17 PM
My442's Avatar
A couple of things:
1.The O4B comes in 2 flavors: Square bore (Holley) and a Spread bore (Q-jet)
2. The HEI will not fit. Add a Pertronix III to a stock distributor. Works great.
shamusj
Dec 18, 2014 09:28 AM
yanktanks
Aug 18, 2014 05:47 PM
svnt442
Jul 17, 2011 04:43 PM
sx455raidercelticfan
Dec 21, 2010 05:19 PM
Oct 18, 2010 07:26 PM
