Vapor blast
Old Jan 11, 2021 | 03:13 AM
shiftbyear's Avatar
Vapor blast
Here's an example of before and after vapor blasting a 70 W30 intake
Old Jan 11, 2021 | 04:26 AM
Excellent!
Do you have the tool to do this or did you have a shop do it for you? I've never heard of vapor blasting before.
Old Jan 11, 2021 | 05:38 AM
VC455's Avatar
Barely Registered
Jesse, the name is a misnomer. It's sandblasting with water and air as the flow medium. The water cushions the impact of the grit, which can be adjusted to give a more lustrous finish--depending on the metal being blasted.
Some European countries prohibited sand blasting, so it got its start there. It's more popular with the motorcycle crowd, so that may be why you've not heard of it.
Gary
Old Jan 11, 2021 | 06:15 AM
scrappie's Avatar
Who did that and what was the cost?
Old Jan 11, 2021 | 12:33 PM
shiftbyear's Avatar
Had it done locally, $60 an hour. Cost depends on how long it takes to get part a uniform finish. The machine is roughly $13,000. I've heard regular sand blasters can be converted for about $2k, but there's a learning curve to get the correct finish. Not feasible for me since I only need a few parts.
https://inlandempire.craigslist.org/...239695643.html
Old Jan 11, 2021 | 04:12 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Intake ****!
Old Jan 12, 2021 | 05:08 AM
WHAT! That's quite steep.
I knew about kits like this but I've read that they don't work too well. FWIW, I think $60 for finishing your intake is a fair price. Did you spray it with clear coat before installing it?
https://www.northerntool.com/shop/to...E&gclsrc=aw.ds
dcurtis61
Sep 22, 2022 07:25 PM
344870M
Apr 7, 2021 04:41 PM
rickw30
Apr 14, 2020 05:45 AM
johnbumb@charter.net
Feb 12, 2020 04:47 PM
asx455
Nov 5, 2019 05:26 AM
