Bypass Heater
Bypass Heater
68 Cutlass S Convertible 350 with jetaway. All stock.
Newbie stupid questions. I bypassed my heater. But what is the best way??
a. Run a hose from the water pump to the manifold?? to keep the circulation.
b. Cap the fitting with rubber hose caps from auto parts store??
c. remove fittings and install metal plugs??
I have used the rubber caps before but they have split and blew out all under pressure twice. Never at a good time. 30 miles from home.
If I replace the fittings with metal plugs, are the threads pipe (NPT) using plumbing plug or standard (Unified Thread Standard (UTS)) using set screw or bolt??
Another stupid question. What pressure of radiator cap 12 lbs or 16 lbs?? Is that why the rubber caps keep blowing out??
Thank you for reading this.
You know that this is going to disable your windshield defroster, right? This is not a great idea.
12 or 16, I'd use 16 and then assure that the hoses and clamps were in good condition. The rubber plugs blow out because they're cheap crap imported from some hellhole.
There is one other method if you want to maintain a stock look. You can put shutoff valves in the manifold and water pump, hook the heater hoses up to them and close the valves so no water goes to the heater.
X2 what Mr. Glenn said. I assume you are having heater core problems and as mentioned above you will lose your defroster. I've never had a 68, is it a major to swap out the heater core? That seem like it would be the best option especially beings it winter..... Tedd
Back in the day, Dad wanted to minimize heat leak in the summer, so he installed a 1/2" shutoff valve in the hose between the heater core and the intake manifold. He'd shut it off in the summer and open it up when it got cool. Years later when I replaced the heater core & hoses, out came the valve. The heat leak in the summer was never enough to bother me.
Thank you all for the input. I think I am going to plug them off. I tried using the caps and they failed twice. So I want a permanent fix. I live in southern California so the heater and defroster are not needed. I only drive it with the top down in good weather, never at night.
It rarely gets below 50 degrees during the winter, so i can only drive it about 300 days a year.
But....but.....won’t the heads get hot?
What about blowing out the intake gasket????
Have I missed any?
70Cutlass_408
Jul 30, 2011 02:50 PM
Kidcutty
Jun 17, 2010 07:48 PM
