Trunk won't open
Old Jun 27, 2020 | 06:45 PM
NoVA_69_442's Avatar
Trunk won't open
So I'm out driving the car around today, opened and closed the trunk several times with no issues, never had any issues opening the trunk before. I go to open it and I get nothing. The key won't even turn a little. Anyone got any ideas as to why this might have happened? I got a spare key that I'm going to try tomorrow and worst case i can go through the back seat. Just curious as to why this all of the sudden happene .
Old Jun 27, 2020 | 07:02 PM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
Just happens sometimes, part failed.
if it dosnt work go threw the back seat like you said.
Good luck!
Old Jun 27, 2020 | 07:23 PM
vCode442's Avatar
Vincit qui se vincit
Have you tried try some lubricant into the keyhole? Mine gets tight sometimes and I’ve loosened it up with CRC lube. Good luck
Old Jun 29, 2020 | 12:42 AM
Ozzie's Avatar
Be sure that you're using the correct key. If it is and the lube doesn't loosen it up, do as you said about going through the back seat. Try to identify the exact shortfall. Sometime an item in the truck can block the mechanism. Perhaps the cylinder failed. Best wishes.
Old Jun 29, 2020 | 01:50 PM
So tried my extra key and also the lube route but trunk still won't. I got the rear seat out and can see the latch, gonna need to get a socket extension, my arm ain't that long. Question, which screws/bolts am i loosening/removing in order to get my trunk open? I can set a couple sets but not entirely sure which one it is that'll do the trick
Old Jun 29, 2020 | 02:04 PM
vCode442's Avatar
Sorry not sure on that - but you may try some lube from inside trunk, it won’t hurt to bathe everything and see if it might loosen up before you start unscrewing things. Good luck and you’ll get it done - stay positive
Old Jun 29, 2020 | 03:47 PM
RetroRanger's Avatar
72 Olds CS
https://classicoldsmobile.com/forums...ot-open-58005/
reply number 8
Copper Nine Eight
Jun 27, 2015 04:37 AM
jag1886
Feb 11, 2014 04:24 PM
Benton Quest
Body work
27
Jan 15, 2013 04:00 PM
68bob
Sep 3, 2009 10:12 AM
1965_F85
Apr 21, 2007 02:03 PM
