455 olds in buick skylark.
Old Apr 24, 2019 | 02:32 PM
Bgdaddy455's Avatar
Please help with this stupid question.
I have a 67 skylark with a 455 olds motor in it and i think the motor mounts need replacing. The engine raises about a 1 1/2 inches on the driver side when shifting into drive from reverse. I also here what sounds to be metal on metal (clang) i also here it sometimes just when i accelerate. I have a new drive shaft, complete new rearend and new u joints. If any cany tell me what mounts i need that would be awesome. I think i need motor mounts and fram mounts for a 67 cutlass because of the engine. Is that correct? Are the big block and small block mounts the same? Does anyone have part numbers etc? I appreciate any help on this.
Old Apr 24, 2019 | 03:18 PM
Read through this
https://classicoldsmobile.com/forums...tion-list.html
Old Apr 24, 2019 | 03:19 PM
442Harv's Avatar
Yes you need frame and motor mounts, I think you can use BB or SB, as long as you buy both the frame and motor the same, big frame, big motor, small frame small motor.
Old Apr 24, 2019 | 03:29 PM
svnt442's Avatar
I think you misunderstood him. The engine is already in the car and he needs to replace the broken mounts.
Old Apr 24, 2019 | 03:49 PM
The problem is that the motor mounts depend on which frame pads were used for the swap. The mounts will either be Anchor P/N 2261 or 2328. Both are cheap at RockAuto.
Old Apr 24, 2019 | 03:58 PM
442Harv's Avatar
Yes I did miss read. Like Joe said, figure out which one you have and buy new ones.
Old Apr 24, 2019 | 04:01 PM
Bgdaddy455's Avatar
Thanks for responding and yes the motor is in the car. Would there be number stamped in the mount? I will be working on the motor this weekend so i could just pull a mount off but i was really hoping to just order the frame and mount that would work so i would have it for this weekend. Im trying to get a couple hundred more miles on the rear before next weekend. Have a trip planned in it if all goes well but i need the mileage so i can change the gear oil.
Old Apr 24, 2019 | 04:04 PM
Bgdaddy455's Avatar
Do the sypmtoms sound correct for the mount be bad. I think that is the problem. How much should the motor move when shifting from drive to reverse and vice versa?
Old Apr 24, 2019 | 06:30 PM
Yes your symptoms are of a split engine mount.
Old Apr 24, 2019 | 08:51 PM
The replacement mounts are about $4 each at RockAuto. Buy one of each and see which matches your old one. Again, ASSUMING the swap used Olds frame mounts, it will either be a 2261 or a 2328. If the swap was Mickey Moused with a torch then all bets are off.
Old Apr 25, 2019 | 12:27 AM
Bgdaddy455's Avatar
Thanks everyone. I went out and looked and from what i can tell from looking up the part number it is the 2261 mounts. I should have some friday..
Old Apr 25, 2019 | 12:08 PM
Bgdaddy455's Avatar
Motor mounts explained
Motor Mount Myths
Largely by Joe Padavano but Published without his Permission
The question of which motor mounts to use when replacing an A-Body (F-85, Cutlass, Cutlass S, Cutlass Supreme, 442) small block with a big block comes up frequently on the Olds mailing list. Here my understanding.
ALL Olds motors (big and small block) have the motor mount bosses in the same location relative to the crank centerline - the only difference is the deck height. The year of the block (or the displacement for that matter) has absolutely NO effect on the type of motor mount to use. The only thing that matters is the matching frame mount. You must use the motor mount that matches the frame mount in the car.
If it was orignally a small block car and you do not intend to change the frame mounts, get small block motor mounts. These will bolt to the big block and will allow the engine to sit in the exact same location relative to the frame as it would have in a factory installation. Alternatively you could use matching big block motor and frame mounts, but for all this extra expense and effort the engine will still be sitting in the same location.
small block engine mounts with small block frame mounts - OK
big block engine mounts with big block frame mounts - OK
small block engine mounts with big block frame mounts - the engine will be 1-2" too low
big block engine mounts with small block frame mounts - the engine will be 1-2" too high
Note, by the way, that the big block isabout an inch taller than the small block when measuring from the crank centerline to the carb flange, so even if you the matching mounts, the air cleaner and valve covers will be higher in the engine compartment. The crank centerline, fan, and flywheel will all be in the same location as they were with the small block.
The only thing you need to remember is that the rubber motor mounts and the metal frame mounts need to match. Nothing else matters.
The Sealed Power catalog (1982) is incorrect and shows:
270-2261 - 1964-69 all V8 exc. w/400
270-2261 - 1970-72 all 350
270-2328 - 1970-72 all 455
270-2380 - 1973-77 all 260, 350R, 455
270-2328 - 1979-80 all 260P and 350N Diesel
270-2380 - 1979-80 all Cutlass Supreme and Calais 350R
270-2380 - 1980 all 307
270-2380 - 1978-81 all 260F gas
270-2328 - 1981 Cutlass Cruiser Station Wagon 260F gas
270-2328 - 1981 all 350N Diesel
This is a classic example of an incorrect catalog listing. The problem is that the 64-69 small block and 65-68 big block motor mounts are identical. The 1969 400 mounts (and 455 for the 69 H/O) were changed to the taller design used on the 69-72 cars. The small block mounts were changed in 1970. The listing should say "1964-69 all V8 exc. 1969 w/400".
History
1964 - 1968 small and big block motor mounts 270-2261
1969 - 1972 small block motor mounts 270-2261
1969 - 1972 big block motor mounts 270-2328
1973 - up small and big block motor mounts 270-2380
The problem started in 1969. The original motor mounts used on the earlier cars were simply two pieces of metal with rubber molded in between - there was no interlocking feature. GM went through a massive recall in the 60s to repair broken motor mounts of this design. As a result, the big block cars, starting in 1969, got the interlocking design. Unfortunately, this design required the motor mount to be taller, so the frame mount was changed to move the cross bolt (the bolt that attaches the motor mount to the frame mount) further down on the frame mount. The 64-68 (and 69 small block) frame mounts have the cross bolt hole about 1 1/2" down from the centerline of the two top bolts that attach the frame mount to the crossmember. On the 69-72 big block mounts, this dimension is about 2 1/4". The rubber motor mounts are correspondingly different (the 69-72 big block motor mount is about 1" taller than the 64-68 V8 (and 69 small block) mounts.
In 1970, Olds redesigned the small block mounts to also incorporate the interlocking feature, but did this in a way that did not require the cross bolt to be moved. Thus the 70-72 small block frame mounts still use the 1 1/2" dimension. There is, however, a difference between the 70-72 small block mounts and the 64-68 V8 (and 69 small block) frame mounts. The raised pad is smaller and biased towards the top of the mount. Thus, I do not think it is possible to use the 70-72 small block motor mounts on the 64-68 frame pads. On the other hand, it probably _is_ possible to use the 68-68 V8 (and 69 small block) mounts on the 70-72 frame mounts.
Finally, starting in 73 Olds realized that there was no reason to maintain two different motor mount designs and went back to using a common motor and frame mount design on both big and small blocks.
And one more word of advice. Don't rely on any catalog, other than the factory parts catalog, to tell you what motor mounts fit where. As I noted in a prior post, the Sealed Power catalog is flat wrong.
Identifying Frame Pads
You can check by measuring from the center of the two top bolts that hold the mount to the frame to the center of the cross bolt that attaches the frame mount to the motor mount. The big block frame mounts will measure about 2 1/4", while small block mounts will measure about 1 1/2". Whichever ones you have (big or small block), get the motor mounts to match.
When bolting the motor mounts to the block, there are three tapped holes on each side. The front two are for full size cars, the back two for Cutlii. Also, when you unbolt the Toro front motor mount (you don't need it for RWD applications), be sure to reinstall the timing tab.
The 1970-earlier B/C body cars use a motor mount that is completely different from the A-body mounts. The rubber mount has a threaded stud that fits into a hole in the frame. A nut is installed from the underside. One other wrinkle is that some B/C body cars DO use a 1" shim under one motor mount (see notes on the Cutlass offset engine myth.) If the shim is there on the 350, use it in the same place on the 455. Also, note that B/C body motor mounts bolt to the forward two of the three bosses on each side of the block. The A-body cars use the rear two bosses.
Q) Are the 69 onward small block motor and frame mounts exactly the same as the early "one size fits all V8's" units.
A) The answer unfortunately is no. The 69-up small block mounts are not the same as the 68-down universal mounts. The net combination of matched motor and frame mounts for a specific year is always the same, but the individual parts may be different from year-to-year.
Q) What is the earliest year motor and frame mounts that will put a V8 into an A-Body?
A) 1964 330 motor and frame mounts used as a matched set will install any 64-up (except, of course, the 394) Olds V8 in a 64 A-body. Ditto for 65, 66, etc.
Q) Are there any better quality mounts or mounts to avoid?
A) General concensus is that the G.M. rubber mounts (made in the U.S.A.) are the best rubber ones. Also, for reference, the Mondello SM300 mounts appear to be solid versions of the Sealed Power 270-2261 mounts and SM400's appear to be the solid version of the 270-2328.
I hope this has been helpful. Please contact me with any questions or corrections at
joe_padavano
Tech Editor's Desk
110
Jan 1, 2026 08:36 AM
edzolz
Aug 21, 2017 08:44 AM
Se7enty5
May 12, 2015 08:48 AM
Dissector
Sep 22, 2013 09:35 AM
gthmcty1
Feb 26, 2009 06:21 PM
