Rear Upper Control Arm Bushings
Old March 1st, 2019, 01:41 PM
F-85 4-4-2's Avatar
1966 FSM states that "The bushings in the (rear) suspension arms can only be serviced by replacing the complete arms." I would think I can replace the bushings, as long as I use a spacer to prevent the (upper) arm from collapsing when I press them in; suggestions?
F-85 4-4-2 is offline
Old March 1st, 2019, 02:51 PM
I've replaced plenty of rear bushings. I never understood that note either. All eight rear bushings are the same P/N.
joe_padavano is offline
Old March 1st, 2019, 03:53 PM
F-85 4-4-2's Avatar
Thanks. Any suggestions on a spacer to hold the flanges apart?
Old March 1st, 2019, 04:05 PM
junior supercar's Avatar
can cut a piece of metal pipe the appropriate size and shape
junior supercar is offline
Old March 1st, 2019, 04:17 PM
I've found a piece of angle iron to work really well.
Old March 1st, 2019, 04:22 PM
F-85 4-4-2's Avatar
I like that "angle". Thanks!
Old March 1st, 2019, 04:24 PM
1968 442 Convertible
bry593's Avatar
I use a piece of exhaust tubing, cut first for width of control arm, then cut again in half lengthwise so as to fit inside the control arm and prevent crush due to press.
bry593 is offline
Old March 2nd, 2019, 10:56 PM
BackInTheGame's Avatar
I use a piece of Sched 40 black PVC pipe, 2" diameter. Works like a champ.
BackInTheGame is offline
Old March 3rd, 2019, 05:06 AM
Rodney
cdrod's Avatar
x2 on the schedule 40 PVC pipe but get the solid wall pipe that's rated for pressure, not the foam-core, lightweight stuff from Home Depot. I did't have a press at the time and did mine with a ball-joint service kit from Harbor Freight.
cdrod is offline
Old March 3rd, 2019, 09:12 AM
F-85 4-4-2's Avatar
I went the Sch 40 black iron route. Took the local Home Depot a few tries to get the right length, then cut it in half at home. Worked well. I needed the extra pieces anyway, for pushing & receiving on the press.
Old March 3rd, 2019, 02:40 PM
Run to Rund's Avatar
The original stiff bushings were 388266 but they were superceded with the soft bushings. For a while Lakewood made some even a bit stiffer PN 20590. That is what I use for racing.
Run to Rund is offline
Old March 3rd, 2019, 03:04 PM
bry593's Avatar
That is brilliant! Never occurred to me. Much easier to cut then steel! Thanks for the tip!
By the way, Moog bushings are a harder durometer than original. Moog claims this synthetic rubber material performs like urethane. I don't know about that, but they do work well and are problem free.
bry593 is offline
Old March 3rd, 2019, 05:07 PM
Schurkey's Avatar
Better yet...install Polyurethane bushings, LEAVE THE ORIGINAL SHELLS IN PLACE, and you have no need for a press or "special tooling" to prevent the colllapse of the arms--because you aren't pressing the shells out.
One of several advantages to the Polyurethane bushings.
Schurkey is offline
Old March 4th, 2019, 07:17 AM
ronskal's Avatar
I had metal fence post scrap (3 inch diameter maybe) that I cut into a C section to place between the ears, worked great.
ronskal is offline
Bee-Oh-Pee
November 1st, 2015 09:42 AM
Harmon
Drivetrain/Differentials
July 28th, 2014 12:07 AM
70cutty
Suspension & Handling
April 3rd, 2013 07:56 AM
costpenn
October 9th, 2011 03:43 PM
t bell
October 23rd, 2009 08:26 AM
Quick Reply: Rear Upper Control Arm Bushings
