Rear Upper Control Arm Bushings
1966 FSM states that "The bushings in the (rear) suspension arms can only be serviced by replacing the complete arms." I would think I can replace the bushings, as long as I use a spacer to prevent the (upper) arm from collapsing when I press them in; suggestions?
I've replaced plenty of rear bushings. I never understood that note either. All eight rear bushings are the same P/N.
x2 on the schedule 40 PVC pipe but get the solid wall pipe that's rated for pressure, not the foam-core, lightweight stuff from Home Depot. I did't have a press at the time and did mine with a ball-joint service kit from Harbor Freight.
I went the Sch 40 black iron route. Took the local Home Depot a few tries to get the right length, then cut it in half at home. Worked well. I needed the extra pieces anyway, for pushing & receiving on the press.
By the way, Moog bushings are a harder durometer than original. Moog claims this synthetic rubber material performs like urethane. I don't know about that, but they do work well and are problem free.
Better yet...install Polyurethane bushings, LEAVE THE ORIGINAL SHELLS IN PLACE, and you have no need for a press or "special tooling" to prevent the colllapse of the arms--because you aren't pressing the shells out.
One of several advantages to the Polyurethane bushings.
costpenn
October 9th, 2011 03:43 PM
